Recently I replaced my Pressure Tank. I am notice small leaks and condensation. The piping coming from the well is mostly black tube piping connected together by gray inserts. The piping from the well directly is metal as you can tell in the picture.
The problem I have is the black tube piping (dont know the exact name of it) gets heavy condensation and has small leaks where it connects together using the gray piping inserts.
Since I also have to re-do a poor weld I did on the copper, I also want to take care of the problems I stated above. Should I just go with metal piping from the wall connection to the T connector? Or should I try to use what's in place just re-check how tight the connections are? Or is there another option? Thanks
