Results 1 to 7 of 7
Thread: Delta single handle faucet hard to turn after parts replacement
    DIY Junior Member Norwegianwood's Avatar
    Jul 2010
    Virginia
    Default Delta single handle faucet hard to turn after parts replacement
    I recently replaced the cam and packing, ball and seats/springs in my 10 year old single handle Delta bathroom faucet. It does not leak from the spout anymore but it is much harder to turn and operate the handle. I have played with the adjusting ring. Any ideas? Thanks.
    You could have an "aftermarket" ball which was not made to the company's specifications.
    Nov 2009
    Victor, MT
    Put some silicone grease on the bottom of the cam washer where it rubs against the ball.
    Jul 2010
    Virginia
    Tom- any specific brand you recommend? Thanks.
    Feb 2005
    Omaha, NE
    Like HJ said - did you use a genuine Delta replacement part? Most of the repair kits in the big box stores are not; it does make a difference.
    IF you used the correct parts, you do NOT need to lubricate the seal. In fact, if you got the newest kit, it should have had the new one piece seal, rather than the rubber washer and plastic cam.
    Jul 2010
    Virginia
    Tom,
    The silicone grease did the trick! Thanks all for your help.
    'Wood
  1. Delta Single handle kitchen faucet not working
    By hamid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2009, 08:53 PM
  2. Delta Single Handle Shower Faucet - Leaking Profusely
    By wbp3 in forum Shower & bathtub Forum & Blog
    Last Post: 06-09-2008, 07:22 AM
  3. Delta single handle won't turn off
    By markrwolfe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2007, 07:28 PM
  4. Diverter handle getting hard to turn
    By blaronn in forum Shower & bathtub Forum & Blog
    Last Post: 11-27-2005, 08:24 AM
  5. Delta shower faucet hard to turn off
    By jpgipson in forum Shower & bathtub Forum & Blog
    Last Post: 10-07-2005, 06:25 AM
