Results 1 to 3 of 3
Thread: Tankless Heater Problem
    DIY Junior Member MrTelco1948's Avatar
    Jul 2010
    Severn, Md.
    Default Tankless Heater Problem
    Installed a S.E.T.S. tankless heater about 10 years ago. Even though it's supposed to do a whole house, I only have it connected to the shower. It has worked great for all this time until a few days ago. During a shower, I heard a loud pop and then had COLD water! Upon examination, the outlet pipe from the heater had blown apart at a 90 degree elbow about 4 inches from the heater. I didn't think it was possible for the water to get hot enough to melt the solder. Could it have been a faulty solder joint even though it has worked fine for 10 years and never leaked? Any thoughts?
    Yakima WA
    You are correct in thinking water can not be heated hot enough to melt solder. The joint must have been faulty. I had a joint separate on my main supply line and shut off valve once. It wasn't 10 years old, but it was at least 3 or 4 years old.
    Jul 2010
    Severn, Md.
    Thanks for taking the time to reply Gary. I'll redo the joint and try the heater again.
  1. Replies: 10
    Last Post: 04-26-2010, 08:09 AM
  2. tankless water heater
    By r_harper in forum Tankless Water Heater Forum
    Last Post: 01-01-2009, 10:51 AM
  3. Tankless Water heater problem...advice needed
    By jed1154 in forum Tankless Water Heater Forum
    Last Post: 08-27-2008, 04:23 PM
  4. Tankless Water heater problem...advice needed
    By jed1154 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. tankless water heater
    By meckroth in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2006, 04:42 PM
