Results 1 to 5 of 5
Thread: How do I replace a cast iron flange?
    DIY Junior Member dy's Avatar
    May 2010
    OH
    Default How do I replace a cast iron flange?
    How do I replace a cast iron flange? It is welded on I think. I removed the screws and it of course didnt come off. I have a new PVC one, but not sure how to get this flange off. The bolts are corroded and old and just keep spinning, so I need to replace it.
    You have a plumber break the old one off and install a new CAST IRON one. The PVC one will NOT WORK. But if the bolts are spinning, you need new bolts, NOT a new flange.
    May 2010
    OH
    I got new bolts, and they keep spinning too. I dont think they are the right size , or do they have different sizes? they were the standard ones that come in with the wax ring.
    I normally use a washer and nut to secure the closet bolt to the flange.
    The hardware stores make you buy two sets, or look in the isle for more 1/4 20 nuts and washers.
    We sell our customers the bags with four nuts and washers.
    Normally they do not spin because they have "oval" heads which fit into a recess on the bottom of the flange, but most of us secure the bolts to the flange with a nut and washer. It makes it easier to remove the next time, because the bolt CANNOT spin.
  1. Replace or fix cast iron toilet flange???
    By Craif in forum Toilet Forum discussions
    Last Post: 11-01-2010, 07:07 PM
  2. Replace cast iron trap with PVC
    By mhopper in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-18-2010, 12:08 PM
  3. To Replace Cast Iron or Not to Replace That is the Question
    By highpeakscontracting in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-18-2009, 06:47 AM
  4. Replace underground cast iron?
    By JAR8832 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-10-2009, 06:15 AM
  5. Replace short run of cast iron.
    By MikeFromHC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2009, 07:04 PM
