Very true.
With said then I will go w/the recommended settings you have stated before of:
Backwash: 10 min
Brine/slow rinse: 45 minutes
Fast rinse: 3 minutes
Brine fill: 3 minutes (assumes salt dose of 4.5 lbs, capacity of 15K, and BLFC of 0.5 gpm)
Then I will make adjustments accordingly to get my desired results. In the long run it sounds as though I may need to get a bigger setup then what I have. Till then I'll make do w/what I have.
Thanks for all your suggestions and guidence. I will continued to reserach and learn this system. I know where to go if I get in a jam.
Again, thanks for all the help you guys have done. I wish the best of success for this forum which is pretty cool.
Backwash: 10 min
