Results 1 to 6 of 6
Thread: Hot (water)time in the summer
    DIY Member dhla's Avatar
    Mar 2009
    Los Angeles
    Default Hot (water)time in the summer
    Got a question - don't know that there's anything I can do to remediate... not sure even where to look, but thought I'd post the situation and see if anyone had any good advice.
    In the summer (in Los Angeles) when it is hot, if I run the water in the mid/late afternoon, even the cold comes out pretty warm, and the hot water comes out very hot. Don't have the problem in the fall/winter/spring, so somewhere along the way, the cold water line must be getting exposed to the sun.
    Any suggestion about how to find/how to remediate? Or just live with it??
    Thank you!
    plumbing contractor worsnup's Avatar
    Jun 2010
    phoenix az
    in phoenix we live with it
    The lines are probably run through the attic. Add more insulation, maybe a reflective barrier to lower the attic temperature and the heat load, and it may help some. Running the pipes through an interior wall in conditioned space would help, but that means tearing up a lot of wall, and then getting it where you want is tougher.
    Dec 2007
    Move North! Our temps run in the high 30's winter - 70's in the summer....
    Default hot
    Usually no cure and you live with it.
    Mar 2009
    Los Angeles
    That's what I figured - thank u!
  1. Winter - Summer Hook Up
    By jwilson in forum Plumbing Forum Discussion & Blog
    Last Post: 05-13-2009, 09:32 AM
  2. *Well Pump keeps shutting off (Rapidaytor) from time to time*
    By h2osho in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-19-2009, 05:53 AM
  3. Outdoor Faucet Alternatives for Summer Use
    By lc1983 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-09-2008, 02:28 PM
  4. Summer Cottage Hot Water Heater Questions
    By BBranch in forum Plumbing Forum Discussion & Blog
    Last Post: 05-09-2008, 05:02 PM
  5. 410A Refrigerant Charging in Winter vs Summer
    By PlumbBobSquarePants in forum HVAC Heating & Cooling
    Last Post: 09-16-2007, 05:58 PM
