The one requirement for ANY freezing to be successful is that you have to be able to stop ALL flow of water through the pipe, otherwise the water will keep thawing it before it completely closes the pipe. One problem is to know when the freezing has been successful, because if you open a faucet to see if the flow has stopped and it is not frozen, you will thaw the blockade and have to start over.The commercial versions use "liquid co2" to freeze it faster. In some cases you use two "bags", one on either side of the area to be repaired.
