Thread: Whirlpool tub used with deck mount tub filler and hand shower
    DIY Junior Member five4fighting81's Avatar
    Jun 2010
    spencerport ny
    Default Whirlpool tub used with deck mount tub filler and hand shower
    Hello all, I am new to the Forum.
    I am remodeling my bathroom and have a 2' x 6' whirlpool tub that I am installing. I would like to have a deck mount tub filler with hand wand as such:
    However, I would also like to have a standard shower head mounted on the wall like in a standard shower.
    How would you guys suggest I plumb this?
    Any help would be appreciated.
    It may be easiest to add a second valve on the wall for the shower head.
    It should be pressure balanced.
    It gets complicated, because you not only need a diverter on the tub valve to transfer water away from the spout, but then you need a three port diverter to select between the two showers. Or you can connect the tub valve to a multiport diverter and select which of the three operations you want to use. DO NOT create a system where ALL of the devices could be turned off at the same time.
    That would create a "cross over" and the hot or cold could pass through the valve to the other side. You have "mixed" the water for the entire home.
  1. Deck Mounted Hand Shower
    By hurlb in forum Shower & bathtub Forum & Blog
    Last Post: 06-26-2010, 06:54 AM
  2. Deck Mounted Hand Shower Question
    By sgtmom in forum Plumbing Forum Discussion & Blog
    Last Post: 10-23-2008, 05:00 PM
  3. Vacuum breaker on deck mount hand held shower
    By Mrikert in forum Shower & bathtub Forum & Blog
    Last Post: 06-04-2008, 05:05 AM
  4. deck mount tub with integral hand held shower diverter
    By jbowler in forum Shower & bathtub Forum & Blog
    Last Post: 04-19-2008, 07:46 AM
  5. Pressure balance on roman filler with hand shower?
    By Vermonster in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2005, 01:28 PM
