Results 1 to 6 of 6
Thread: Can a Myers deep well pump be used as a shallow well pump?
    DIY Junior Member dave115's Avatar
    Jun 2010
    Alum Bank PA
    Default Can a Myers deep well pump be used as a shallow well pump?
    I have an old Myers deep well pump that I would like to use to draw water from a shallow hand dug well.
    The model I have is does not accept the conversion kit. Can I simply plug the outlet that returns water to the foot valve in the deep well to draw water from the shallow well?
    Moderator valveman's Avatar
    Mar 2006
    No. But you can still use the jet assembly even in a shallow well. Just have to use both pipe down the well even for a shallow well.
    Jun 2010
    Alum Bank PA
    Thanks Valveman!
    I have the pump connected to the well as originally described, and it does move water, but it does not build pressure to fill a pressure tank. I have ordered the part and tubing to connect as you described.
    DIY Junior Member Dana Whitt's Avatar
    Nov 2013
    North Carolina
    Hi valveman my husband and I just brought a house the bank we brought it from recently replaced the pump with a utilitech deep well jet pump. Well since moving in the pvc that goes from the pump to the well cap has started leaking twice. We got it fixed and now it is leaking again, any suggestion?
    P.s. When it leaks it spurts out it is not just a slow leak it fill the well house.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Depends on where the leak is, if its the pipe that keeps splitting, replace the pipe or you will be chasing it forever
    Mar 2006
    I would guess the leak happens where the plastic pipe connects to the pump? If so the pump is getting hot. Either you have a suction line leak, or the pump can’t build enough pressure to reach the shut off point of the pressure switch. Pump model number, depth of well??
  1. Myers jet pump conversion to shallow well??
    By atfdmike in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-29-2011, 07:57 AM
  2. shallow well with a deep well pump?
    By vtarasuk in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-27-2009, 03:12 PM
  3. shallow or deep well pump
    By plmitchell in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-08-2009, 09:47 AM
  4. Jet pump, Deep vs shallow
    By pgreco44 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2009, 05:53 AM
  5. myers shallow well jet pump not working, help!
    By mlfbellingham in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-07-2006, 12:36 PM
