Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: toilet wet vent in Canada
  1. #16
    Jun 2009
    Penticton, BC
    Quote Originally Posted by Wally Hays View Post
    Not by the 09 IPC it ain't. You can not have the wet vent running off a branch from the main line. In that particular drawing there is no vent for the tub if the lav is draining
    He's from Canada and falls under NPC of Canada. Not the IPC.
  2. #17
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    The only thing that I find questionable is the section in the green circle. The 2 fixtures are not both draining in the same vertical continuous waste and vent.
    That's the way I interpret the code anyway
  3. #18
    Jun 2009
    Penticton, BC
    Quote Originally Posted by krow View Post
    You mean the tub and the sink? If so then what you quoted from the code book wouldn't apply because they're not both wet venting fixtures. Only the lav is a wet venting fixture.
    The code clause you quoted is referring to a system where you have to wet vented fixtures draining into a vertical soil or waste stack, or branch, or w/e and they are connected at the SAME vertical elevation you must connect them with a double fitting.
    There is only one vertical portion of piping that is wet vented and that's from the sink.
  4. #19
    Feb 2008
    Ontario, Canada
    Quote Originally Posted by Doherty Plumbing View Post
    The qouted clause refers to 2 wet venting fixtures venting 1 fixture, in this case the toilet. The tub needs to be seperately vented and the lav becomes the wet venting fixture for the toilet.(as the latter part of the qoute states), that is the way I am interpreting it.
  5. #20
    Jun 2009
    Penticton, BC
    Krow not to be argumentative but how would you wet vent a bathroom group in a basement then?
  6. #21
    DIY Member christoff's Avatar
    Dec 2007
    Toronto Canada
    inspection passed today as a wc,lav,and bath tub wet vent, shower dry vented at a 45 degree angle as discussed previously thanks again mr doherty.
  7. #22
    Jun 2009
    Penticton, BC
    Quote Originally Posted by christoff View Post
    No problem, Sir.
  1. Toilet Shower Sink drain venting, Canada
    By dodge1930 in forum Canadian Plumbing Code Questions
    Last Post: 10-28-2010, 08:01 PM
  2. Toilet Shower Sink drain venting, Canada
    By dodge1930 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2010, 09:15 AM
  3. double sanitary tee in Canada
    By segal46 in forum Canadian Plumbing Code Questions
    Last Post: 06-26-2010, 08:37 PM
  4. double sanitary tee in Canada
    By segal46 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. toilet waste and vent in Canada
    By christoff in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2010, 07:10 PM
