Thread: Moen Single Handle shower- no cold water???
    DIY Junior Member b00mstick11's Avatar
    Jun 2010
    Arlington, TN
    Default Moen Single Handle shower- no cold water???
    I have a Moen Single Handle Shower ( Posi temp version ) and it's only trickling water in the cold position. Once you get it to about 12 o' clock it comes on full hot with no in between. It's only 1 1/2 years old. Does the stem need replacing? I also see 2 adjustment screws on either side of the valve in the wall. What are they for? Thanks.......
    Dec 2007
    Replace the cartridge
    Call Moen For Free Parts
    1-800-BUY-MOEN
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    Quote Originally Posted by b00mstick11 View Post
    Are you sure it is a "positemp?" Correct me if I'm wrong, The only valve that I know that has the 2 "screws" on iether side (shut off valves/stops), is the moentrol.
    If it is a moentrol, you will need a balancing spool
  1. Temperature Settings on Moen Single Handle Tub/Shower Faucet
    By shelleyevans in forum Shower & bathtub Forum & Blog
    Last Post: 11-28-2011, 05:20 PM
  2. How to take out Moen Single handle rotary shower.
    By canadianexpress in forum Shower & bathtub Forum & Blog
    Last Post: 05-09-2010, 06:56 PM
  3. Moen Single Handle Shower/Tub valve problem
    By short.circuit in forum Shower & bathtub Forum & Blog
    Last Post: 04-16-2009, 06:46 AM
  4. Unclip handle hose for moen single?
    By tfcallahan1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2009, 01:14 PM
  5. Moen single handle tub/shower valve
    By marichpt in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2005, 05:19 AM
