Results 1 to 5 of 5
Thread: Supply 3 shower heads with 1/2" pex
    DIY Junior Member insulated's Avatar
    Jun 2010
    Plano, TX
    Default Supply 3 shower heads with 1/2" pex
    I am in the middle of a bath remodel. The original copper lines in the wall for the shower had the 1/2" supply for hot capped, probably due to a leak or low pressure. It was done when the house was built. They put a T on the garden tub stub up which is in the middle of the floor and ran that line under the shower pan to the shower wet wall next to the cold supply. When I tore out the tub and shower I discovered that I have no way to supply the new shower. The water heater is on the other side of the house, and this remodel bath has no attic.
    I don't want to tear up the slab if possible.
    Can I run 1/2" pex off a 1/2" copper supply under the sink through the wall and still get enough water to supply a 3/4" valve and 3 separate volume controls feeding 3 shower heads? Will I lose volume through the pex connection, or the 15' of pex I need to do the run?
    Jan 2006
    Rosedale, Md
    Doesn't sound like a good idea, 3/4 should be run to the area and 1/2 taken off for each valve, sorry.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Unless you're running Upnor, you should be running 1" pex lines to that valve to really take full advantage of the 3/4" copper inlets, otherwise you may as well just use a regular rough valve with 1/2" crimp inlets.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Have you LOOKED at 1/2" PEX? The opening in the pipe is really about 3/8", (and the insert fittings reduce it even more, especially if you use the plastic ones), so you will get minimal flow to your valve. 1/2" copper would probably deliver adequate flow to your 3/4" valves because of the internal opening sizes, but PEX has between a half and two thirds the capacity of copper.
    Jun 2007
    Victoria, BC
    ...and that's why I said 1" pex was needed to do it properly.
  1. 1/2" PEX supply lines to Moen Shower valve
    By spooner in forum Shower & bathtub Forum & Blog
    Last Post: 12-11-2012, 04:46 PM
  2. Is 1/2" PEX supply big enough for dual shower head?
    By KSHandyMan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2010, 10:48 AM
  3. 3/4" supply to shower?
    By Patrick North in forum Shower & bathtub Forum & Blog
    Last Post: 03-04-2010, 06:34 AM
  4. 3/4" vs. 1/2" supply to shower?
    By knoctor in forum Shower & bathtub Forum & Blog
    Last Post: 11-02-2009, 09:39 AM
  5. Heads "ooze" water after cycle ends
    By siverhus in forum Irrigation / Sprinkler Forum
    Last Post: 06-20-2007, 04:20 AM
