coaster16
Hi all,
I'm trying to replace a White Rodgers IF92-71 and can't seem to find the installation manual to check a couple of the wires, and wondered if anyone knows this one. I'm hooking up a Trane XE1000 heat pump with Trane TWEO36C air handler to a Honeywell/Trane TH8320 Tstat. Most of the wires on the IF92 have equivalents on the Honeywell, but a couple don't. In particular, the black wire currently hooked to the IF92's E1 has no equivalent on the Honeywell. I'm assuming it should go to the X2 position. Is that right? The wiring from the two tstats is:
previously hooked up to White/Rodgers IF92-71
O - (OR)orange Red Jumper - W1
B - (BL) black - E1
Y1 - Red Jumper,(YL)yellow - E2
Y2 - - L
C - (BL) blue (RD)red - R
G - (GR) green (WH)white - W2
- W3
wires from trane air handler not connected brown, pink, gray
Connections available on Honeywell/Trane TH8320
Y2 RC jumpered to R below
F R
X2 O
W1 Y
S1 G
S2 B
Thanks for any help.
B - (BL) black - E1
Y2 - - L
- W3
F R
X2 O
W1 Y
S1 G
S2 B
