Results 1 to 6 of 6
Thread: Little silver-winged flying bugs in my drain.... what are they?
    DIY Senior Member DavidTu's Avatar
    Dec 2009
    Seattle, WA
    Default Little silver-winged flying bugs in my drain.... what are they?
    Well the subject gives the description... I can take and post a photo if needed... anyway, at this point I've had to remove the main stack completely down to the foundation floor to clear out debris at the bottom of the drain (yes, I had to reach down there!) and now I notice that there are these little bugs flying around and walking on the remaining pipe below, going to the sewer. Are these things anything to worry about? What are they? How to get rid of them?
    (They're smaller than a fly, bigger than a knat and have silvery wings that fold up like a windsurfing sail.)
    Dec 2007
    They are referred to as filter flies, drain flies or, sewer flies.
    They can be difficult to control... Google "Filter Fly"
    Usually they are an indicator of a dried out trap or other breech of the drain and vent system of your home.
    Dec 2009
    Seattle, WA
    Thanks for ID'ing these for me! In this case I am seeing them right at the point where the building drain exits the foundation... basically there is a cast iron hub right at floor-level and nothing above it... so there is no trap, obviously, between that and the sewer. Given this does it imply there is a breech in the sewer or pipe leading from sewer to the foundation or were you assuming I was seeing these "upstream" in the drainage system?
    Dec 2007
    Oh I'm sorry I misread your post...
    I guess you could say If you have cut the pipe and it is open you have a breech in the drain...
    It would be quite normal for them to be inside of a sewer pipe.
    Usually traps on fixtures keep them at bay....
    Dec 2009
    Seattle, WA
    Thanks for clarifying Redwood... so sounds like don't have to do anything on it. However, once the plumbing system is reattached it will be a while before we have filled traps... so I am wondering if anyone recommends the product "Invade Hot Spot" or another product that would keep them at bay meanwhile?
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Go whole "hog" and spend $5.00 or so at the box store and put in a sewer plug like real
    plumbers do all the time while working on remodel ! !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  1. Kill lawn bugs with your hose, is it legal?
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-05-2012, 08:51 AM
  2. Silver solder 4%?
    By ron350 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2007, 10:26 AM
  3. Little bugs
    By Gouranga in forum Remodel Forum & Blog
    Last Post: 06-26-2006, 03:41 AM
  4. Solder or braze...copper rod or Silver rod?
    By Mikebarone in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-23-2006, 06:48 AM
  5. Is 1 1/2" drain pipe ok for shower drain? and 2nd floor P-trap question...
    By paule123 in forum Shower & bathtub Forum & Blog
    Last Post: 06-12-2005, 10:15 AM
