Results 1 to 8 of 8
Thread: Hot water at cold side all faucets
    DIY Junior Member ben1111's Avatar
    Jun 2010
    illinois
    Default Hot water at cold side all faucets
    Hello,
    I have a home in Chicago that has hot water to all faucets on cold side. There are Grohe thermostatic valves at all showers (4). Only recent work was a new water heater 3 months ago. I am at a loss any help would be appriciated! Thanks in advance!
    Ben
    Plumber Esquire's Avatar
    Nov 2009
    Newfoundland
    Were they normal at some point? If just one of those faucets was failing there could be a potential cross connection. I have seen a couple of occassions where this has happened, but it has usually been with a cheap brand faucet.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Or more likely eather the water heater was hook up wrong i have seen even professional
    plumbers do this !
    Or you could be missing the dip tube ?
    If this problem started about same time as wtr/htr was changed out that is where you
    need to start looking !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Aug 2007
    Check your messages on your profile page ! ! !
    MACPLUMB 777
    E-MAIL
    Reversing the connections to a water heater does NOT change the hot/cold orientation of the faucets. ALL it does is reduce the amount of hot water available. Changing hot to cold, and vice versa, requires a piping change somewhere.
    Plumber jimbo's Avatar
    Do you have any kind of recirulating system? A failed check valve or improperly installed system could be a problem. If you have a retrofit recir, then warm to hot at the cold tap is a normal side effect. If you run a cold tap for a few minutes, does it turn cold, or stay hot?
    Jun 2010
    illinois
    Thanks for the replies. There is not a recirc line, and the water heater was replaced 3 months ago and worked fine untill three days ago. I think that the check valves in one of the Grohe thermostatic mixing valve hav gone bad allowing the water to pass? They are all about 4 years old. I have read that the washing machine selonoid gould also be bad. I will look further into this, and hape to find a resolution to it.
    The water will eventually get "cold", but stays warm for a while!
    Washing machine solenoid valves CANNOT cause the problem, regardless of what you have heard.
  1. Hot water from cold faucets
    By jackstephan2000 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-11-2008, 02:36 PM
  2. Moen 87780SL leaking on cold side only
    By Zaknefien66 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-20-2007, 05:43 AM
  3. hot water from the cold faucets!
    By mikeconte in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-30-2007, 08:16 AM
  4. Hot water on cold side when pump on
    By wschmidt in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-21-2006, 07:20 AM
  5. Hot water recirc. pump problem:Hot from cold faucets
    By dgallagher in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-11-2005, 12:42 AM
