Results 1 to 2 of 2
Thread: PermaHeat Bath Heater
    DIY Junior Member Pegasus"143"'s Avatar
    Jun 2010
    Tx
    Default PermaHeat Bath Heater Not Powering on.
    I purchased a Permaheat m/n 935113 heater and installed in new tub installation. My problem is that the heater power indicator light is not lit and no heat is produced when pump is running. It is plugged into a seperate GFCI outlet. Also this is a vacuum side pump. Any help with where to start diagnosis would be appreciated.
    Jun 2010
    Tx
    :::UPDATE :::
    Found that there was not enough suction pressure to trip the vacuum switch. By partially blocking the suction port the unit switches on and begins to heat.
    Question now is the switch calibratable or does anyone no where I can order just a switch?
  1. Bath Heater Problem
    By CowboyE in forum Shower & bathtub Forum & Blog
    Last Post: 11-19-2009, 10:13 PM
  2. 1/2 bath to 3/4 bath home improvement
    By JONES-SMITH in forum Plumbing Forum Discussion & Blog
    Last Post: 11-16-2008, 03:07 PM
  3. Bath/Shower Valve Not Turning Off Bath Water
    By tricky in forum Shower & bathtub Forum & Blog
    Last Post: 12-16-2007, 08:19 AM
  4. Bath/Shower Valve Not Turning Off Bath Water
    By tricky in forum Plumbing Forum Discussion & Blog
    Last Post: 12-15-2007, 08:41 PM
  5. Sealing a bath (keep bath full for ? hours)
    By MaccGaz in forum Shower & bathtub Forum & Blog
    Last Post: 01-15-2007, 10:29 AM
