Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: Help Programming a Fleck 7000 SXT
  1. #31
    In the Trades Wally Hays's Avatar
    Nov 2009
    Gary, I was sizing, selling, installing and servicing filtration equipment when you were still an insurance salesman. Although you would like us to believe that nobody in the world understands and can zize equipment, believe me, we can and do. As for reading and comprehending your post, I must admit that I did not give it much of my time because, as I just said, I've been doing this for many many years.
    Perception is 3/4 of reality
  2. #32
    Quote Originally Posted by Wally Hays View Post
    I was just wondering if 3333g/p was considered an efficient, or high efficient setting.
  3. #33
    DIY Senior Member Bob999's Avatar
    Jul 2009
    Pennsylvania
    Quote Originally Posted by big dripper View Post
    It is an efficient setting but higher efficiencies are possible, depending on your water conditions.
    See p. 4 in the linked document. Use the column for P-100.
    http://www.caitechnologies.com/image...pecs/SST60.pdf
  4. #34
    Not sure if I missed something here. If you use 3lb per regeneration and it goes 24 days, wouldn't that be 9lb.? Are you saying that 3333gr/lb is a good setting? High efficiency? What would the settings be for a 4000 or 5000 gr/lb setting?
    Yes, 9# (3*3) for the 24-days (at 8, 16, and day 24). The grains/pound is still correct, and it is still less salt for equivalent soft water. Gary mistyped, I think. The end result is while you could run the resin into the ground, i.e., down to zero capacity left after 24-days, it is not the most efficient way to do it. My guess, and this is an educated guess, is that similar to batteries, it's not the best way to get longevity with the resin to run it down to zero each cycle. If it started fully recharged, and you used say a third, and then recharged that third, if there were occasional guests, or heavy water usage, you'd probably handle that better as well rather than running it down fully.
    There are multiple ways to program any system. Some work better than others. SOme make the system last longer. Some create operational problems (like salt bridges, or hard water bleed through). Some are more efficient in the use of expendables. You can handle the operation many ways. Some solutions work most of the time, some work all of the time. Some people can accept it not working all of the time. Lack of good flow from the well could have consequences, and some ignore that to their peril. A well that can change based on the water table needs possibly some extra margin. Each situation is different (but similar). Some want maximum efficiency. So, depending on your use patterns, your tolerance for occasional bleed through, and costs, your priorities may differ and your programming solution may vary. But, quibbling is counter productive. There are consequences to the decisions you make, and IF you are aware of them, and they are acceptable to you, then that's an okay solution. Many people don't care or want to understand what can be a complex situation, and want THE solution...well, there isn't ONE. Being educated as to the consequences of any desicion, to me, is worth the hassle of the investigation. To some, they just want an answer, no explanations, no what ifs, no consequences.
    Might I suggest, when anyone provides an answer, they explain the consequences of that solution. I think Gary does this more than others, and because of that explanation and the fact that it can take a bit to explain, people then get confused. Personally, I generally don't have an issue with it, but then I've spent my whole life in highly technical things - missile and radar systems require attention to detail, and little tolerance for failure or problems. Most things in life don't have as severe consequences if they don't work properly. But, that is not to say that some things aren't complex.
    We spend too much time bashing each other, and need to look at the solution and the benefits and consequences. More than one way will work. Point out where your solution works and why. Don't bash the others if they don't do it 'your' way. It's likely both can work, and you may not have considered the consequences, or they just aren't important to you since they don't happen often. Just like all of the codes we have for plumbing...most stuff will work fine if you take a shortcut. It only gives you grief under certain (unforseen, at least to you) circumstances...and if you don't do it to code, it could fail. Soft water isn't as critical, but some people have no tolerance for 'different'.
    Let's try to keep this more civil. If you keep poking, eventually, that person will poke back. Keep it civil, and expain why and the consequences of that why, and then people can choose their tolerance level for themselves to the possible consequences.
  5. #35
    Quote Originally Posted by Bob999 View Post
    Thanks. Isn't SST60 a specialty resin? Standard or fine mesh resins are more common and most dealers offer either of those. California requires 4000 gr/lb and there are softeners that exceed 5000 gr/lb. I wouldn't really consider 3333 very highly efficient.
  6. #36
    Jul 2009
    Pennsylvania
    Yes SST-60 is a branded specialty resin. Standard "high capacity" and fine mesh resins are more frequently standard choices at online retailers but a few do also offer SST-60 as a choice and I think most will supply it upon request.
    5000 grains per pound of resin is not typically achieved in the real world in my opinion. As you can see from the SST-60 spec sheet it is approached at very low salt dose levels. Even with fine mesh resins it is very difficult to achieve. See spec sheet here:
    http://www.reskem.com/pdf/purolite-c100ef.pdf
  7. #37
    Nov 2009
    Bob, more than half of the systems we sell, we put sst resin in. Jim, thank you for that usefull post, well said.
  1. Clack WS 1 programming PLEASE HELP
    By ryanc in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-11-2010, 12:32 PM
  2. Pegaus series 7000 Cartridge
    By shawv in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2007, 03:56 PM
  3. Fleck 5600SE water softener programming
    By mulman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2007, 08:00 AM
  4. Pegasus 7000
    By jmitchum in forum Shower & bathtub Forum & Blog
    Last Post: 06-20-2007, 02:40 PM
  5. fleck 7000 or clack ?? help
    By gerrythegreat in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-24-2006, 08:30 PM
