I am replacing my downstairs shower
The old shower mixer had 3/4" input feeds fed from 22mm pipes to hot
and cold tanks, and a standard (1/2"?) feed to the shower head.
It is a tall house, so I had good pressure and flow from this.
The new mixer I have bought has only 1/2" inputs, with the same
standard output
The question is: Am I going to lose pressure/flow form the smaller
input pipes? The 22mm feeds come up to the mixer, but then are dropped
to 15mm on entry. I presume the mixer itself will reduce pressure/flow
aswell, so will this be a problem.
Should I forget the mixer I have bought, and find one with 3/4" inputs?
If so, can someone suggest one somewhat like this
, but with the larger inputs (and not absurdly expensive)?
Neal
standard output
Neal
