Results 1 to 2 of 2
Thread: sink drain with washer drain ?
    DIY Member tregg's Avatar
    Dec 2009
    Iowa
    Default sink drain with washer drain ?
    I'm remodeling my kitchen. In the basement the washer drains into a vertical 2 1/2" pipe that stands about 4 feet tall. Is there a problem with running the new kitchen sink drain into that also? I can put a Y on top. Thanks!
    You can't dump an upstairs fixture into the top of the downstairs fixture.
    It siphons the p-trap.
    Any would would need to come in below the tee and p-trap.
    The vent for the downstairs fixture would need to tie into the vent above at 42" above the floor.
  1. Why do I need to vent this washer/sink drain?
    By AllenEllis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2010, 05:36 PM
  2. add laundry sink to washer drain?
    By djbabyk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2008, 08:19 AM
  3. washer drain fills sink
    By flange in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-01-2008, 08:57 AM
  4. Pop-up Sink Drain install - off center sink drain???
    By JeffH in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2006, 11:03 PM
  5. Connecting washer drain into 2" copper drain
    By hugscot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-27-2005, 08:05 PM
