Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
Thread: double sanitary tee in Canada
  1. #31
    Nov 2005
    OK, good to know. I'll remember all this next time I need this.
    1. a bribe over the phone doesn't work, in Canada.
    2. Wolseley ABSTYD2X1K.
  2. #32
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Very few people in Canada actually even know a double fixture fitting exists; it is not used at all (neither are long sweep fittings for that matter). It is a part that has to be special ordered by the supply house from the manufacturer...and you have to know the catalog # to get them to order the proper fitting...if you just tell them you want a double fixture fitting, they will try to give you a double sanitary tee or look at you strangely. Many plumbers know that a double sanitary tee is bad, but they end up using a double wye instead...which is even worse than a double sanitary tee for other reasons.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
  3. #33
    DIY Member christoff's Avatar
    Dec 2007
    Toronto Canada
    Give me a couple of hours and I will post a picture of what you can do.
    any chance of getting that picture terry. thanks
  4. #34
    Nov 2009
    VA
Size:  3.6 KBHow about something like this? It adds some fittings and pipe, but would eliminate the s-trap. If the double combo was used, the cleanout probably wouldn't be needed.
    We'll see what the pros say. Terry might have a better way of doing it (I just quickly pulled something together that should work).
  5. #35
    Dec 2007
    Toronto Canada
    well could this be another possibility.
  6. #36
    You have 2" from the bottom?
    Then why were you showing a 1.5" double san cross before?
    The laundry tub should have a 2 x 1.5 x 1.5" santee if you are coming up from the vertical.
    Or the 2 x 1.5 x 1.5 x 1.5 fixture cross would have worked.
    The picture below is a 1.5" being split for two lavs without the cross fitting.
    To be UPC legal, it would need 2" until it's split.
    But if you only had 1.5" in the floor, this would be the best fix.
  7. #37
    Dec 2007
    Toronto Canada
    yes this looks alot more compact than mine, would mine even pass terry?
    the 2" is the main drain that will go to the 3" drain. i have the toilet wet vented through the lav as the last vent before the entrance to the 4 " drain to the sewer
    i was showing the san tee last night when you said you were going to post a pic, then i tried to draw a pic as well hense the new setup.
  8. #38
    Dec 2007
    Toronto Canada
    this is what i was going to do until i was told not to use a double san tee
  9. #39
    Jun 2009
    Penticton, BC
    Quote Originally Posted by christoff View Post
    I'm not a big fan of the short sweet 90's you have there, but if you changed those to 45* elbows your setup would be 100% code legal here in Canada.
  10. #40
    The family had a log cabin in Canada.
    The toilet was an outhouse, code legal, and the kitchen sink was a pipe that went outside into the sand, that was code legal too.
    Can a da.
    Where the bears drink beer.
    We had a bear that would come around mainly at night.
    In the US, were still not big fans of the code legal in Can a da san cross. That's always been a tough one to snake.
    But then there are rough-in plumbers, and there are service plumbers.
    When you get tired of doing crawlers, you become a service plumber.
    Though, I had to slither a crawl today for a repipe bid that the young guys will be doing.
    What was I thinking, after three surgeries on through my stomach muscles this Winter, that was hard.
  11. #41
    Jun 2009
    Penticton, BC
    By code you should have cleanout on the branch below the double san-T. This makes snaking easy.
  12. #42
    The problem me and hj have had, was dropping the snake down the sancross.
    You can put a cleanout below, but that still leaves a section that you can't snake.
    We don't use the sancross south of Can a da.
    That's why it's nice to know where people are installing these things.
    For myself, I prefer to plumb not just to code, which is a bare minimum, but to plumb so that it works long term. It doesn't really take much.
    hj is as old as the Grand Canyon, and I'm a decade or so behind him, so we think differently. We think more like service plumbers, wishing the rough-in guys would get their act together.
    So the sancross is legal in Canada, not the US
    What other American countries use the sancross?
    Mexico?
    Guatemala?
    Belize?
  13. #43
    DIY Senior Member Rich B's Avatar
    Sep 2008
    New Jersey
    Pretty good band.......I am pretty old but listen to nothing but Rock and like it.......new, old, everything in between......Lots of good bands out there today with similar sounds that made it big.....Good Luck to them......
  14. #44
    Jun 2009
    Penticton, BC
    What section would you not beable to snake? You could run the snake down each trap arm and then open up the clean-out and snake up AND down the piping all the way out to the city sewer or roof vent if you wanted to do that.
    We don't use "double fixture tees" or w/e you guys call them. Atleast not here in BC and you won't find reference to them in the code book anywhere. That I know of anyway
  1. Double fixture tee or double sanitary tee?
    By nc8861 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-03-2011, 11:33 AM
  2. Canada shower question--just wondering
    By timsean in forum Shower & bathtub Forum & Blog
    Last Post: 03-12-2010, 12:55 PM
  3. Driven well supply in Alberta or Canada
    By km74 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-14-2008, 07:08 AM
  4. Double Sanitary Tee or Double Wye?
    By MG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-26-2007, 11:45 AM
  5. Venting sizes in Ontario Canada
    By the_slowpoke in forum Remodel Forum & Blog
    Last Post: 03-11-2007, 05:25 PM
