Results 1 to 8 of 8
Thread: Iron Removal for single tub.
    DIY Junior Member Gast's Avatar
    Jun 2010
    GA
    Default Iron Removal for single tub.
    My parents have a tub with water jets that hasn't been hooked up to the water lines for almost 10 years due to fear that our well water will destroy the tub. I'm pretty sure we've got hard water and a sizable iron count. I really don't have the budget to put in a whole house system, so I'd like to know if I have any options for a smaller scale iron filter. (Ha! Sorry for pun.) My only goal is to get the water quality to a point that it won't harm the tub. I'll try and get the water tested soon.
    In the Trades Wally Hays's Avatar
    Nov 2009
    first test the water and the results will give you your options.
    Perception is 3/4 of reality
    Jun 2010
    GA
    Aww, I was hoping for some ideas before then. I was told it takes an average of a week to get results for water tests done by the county. IIRC our iron was in the single digits (3-5), and I remember being well into the "hard water" category.
    Depending on how much, and what type of iron compound is in the water would determine how you could remove it, and what would work. A softener can remove some iron in the process of softening the water, but if the water is very heavily loaded, you may need other process(es) to clear it. You may want to do this for the whole house, as getting access to the supply and having room for maintenance and the initial install could be tough.
    Jun 2010
    GA
    Access to the supply and room to install and maintain any system installed is not really a problem, overall cost is. When we built the house there was a miscommunication about the crawl space height, so it's now more of a crouch space, and the access door is under the bathroom in question. And there's enough space in the bathroom itself to potentially build a cabinet to house a system right next to the tub.
    As for cost, I'd have to keep it under $500, preferably under $200. I'm fairly handy and plan on installing the system myself.
    DIY Senior Member Bob999's Avatar
    Jul 2009
    Pennsylvania
    Iron stains but does not generally destroy surfaces like a tub. If there is high iron content then other surfaces (sinks, toilets, etc) are staining and you can expect the same with the tub. So why do you have special concerns about the tub?
    Jun 2010
    GA
    It's a whirlpool or jacuzzi tub. It has water jets and pumps and stuff that my parents won't think will hold up well to the water. The shower heads don't fare so well, so I can understand their concern.
    Jul 2009
    Pennsylvania
    Quote Originally Posted by Gast View Post
    Good reasons to treat all the water--not just for the tub. But as Wally said--you need a water test before anyone can give you informed advice.
    Added: An additional consideration is tubs have both hot and cold water supply and most filters are not rated to use with hot water. That means you need to treat the water before it enters the hot water heater.
  1. Cast Iron pipe - Lead removal and resealing
    By tnr122 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-28-2010, 02:25 PM
  2. Softeners, resin, and iron removal
    By Ddanrr in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-04-2009, 08:42 PM
  3. Removal of Single Handle Gerber Faucet
    By bchager in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2009, 07:00 PM
  4. Claw Foot Cast Iron Tub removal
    By nwnewbie in forum Shower & bathtub Forum & Blog
    Last Post: 08-23-2007, 08:13 PM
  5. Lead pipe to cast iron p-trap removal.
    By Irdaniam in forum Shower & bathtub Forum & Blog
    Last Post: 01-24-2006, 05:38 AM
