Results 1 to 7 of 7
Thread: floor drain, Canada
Hybrid View
    DIY Member christoff's Avatar
    Dec 2007
    Toronto Canada
    Default floor drain, Canada
    hello, i have a drain in my basement floor that is joined to a clay pipe and appears to go toward the outside of the house not attached to the drain that goes to the street . i assume that it is a drain to the outside weepers in case of a flood. my question is can i not use that clay pipe and make a 3" drain and put it into the 4" sewer pipe that goes to the street? this clay pipe is in the way, stopping me from getting enough drop for the 3" toilet drain
    also i am wet venting a toilet from the 2" lav drain, does the connection have to be the last one on the 3" toilet drain behind the shower and bathtub? connections. thanks
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    The old clay may be coming from an old downspout drain. It depends on where it is coming from and where it ends up going.
    The wet vent should be closest to the toliet. The shower/bath drains should be further than the toilet.
    Dec 2007
    Toronto Canada
    i just did some more concrete breaking, and there is another 4" clay y connection on the sewer drain that is hooked into the floor drain, so the floor drain has 2 outlets 1 seems to go to the weeping tiles or visa versa, and the other to the sewer. can i block off the weeper side and just use the floor drain as it was installed 58 years ago, am i correct? or how can i deal with this situation code wise in my area? thank you
    Feb 2008
    Ontario, Canada
    The pipe that you see going to the "weeping tile" is probably a downspout drain. In the old days, they used to connect the eaves trough drains to the floor drain in the basement. If in fact you are correct that it connects to the weeping tile, i would not disconnect it unless you have another floor drain that will pick up the weepers. If you do disconnect it (its called a running trap}, you will now have to prime the floor drain . You will have to find a way to connect fresh water to replenish the water in the floor drain. The water in the FD will eventually evaporate.
    The prime can come from a laundry sink faucet or a toilet fill valve or an automatic trap seal primer, etc........ There are so many ways to connect it, its just a matter of which way is convenient for you
    Dec 2007
    Toronto Canada
    hi krow i was speaking to someone who also thinks that it is an old downspout drain, can i block off those clay pipes and leave the drain in tact to pass inspection? also i have a drain from the high eff. furnace that drains alot of water to that drain to keep it wet for the trap thanks
    Feb 2008
    Ontario, Canada
    Quote Originally Posted by christoff View Post
    hi know i was speaking to someone who also thinks that it is an old downspout drain, can i block off those clay pipes and leave the drain in tact to pass inspection?
    If your downspout is disconnected from the drain. Have the downspout diverted to your lawn and cap the exterior as well as what ever you need to connect inside. The inspector may still want you to put a primer, regardless of the high eff furnace. It depends on the individual inspector.
    I have had inspectors in T.O. have me remove and replace existing clay floor drains to pvc because we were doing a new bathroom rough-in in the vicinity. . The minute you touch the existing or part of, you are expected to be obligated to renew that entire portion and be code compliant.
    as I said, it depends on the individual inspector for your area. He/she may be a nice guy/gal and close one eye.
  1. Toilet Shower Sink drain venting, Canada
    By dodge1930 in forum Canadian Plumbing Code Questions
    Last Post: 10-28-2010, 08:01 PM
  2. Toilet Shower Sink drain venting, Canada
    By dodge1930 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2010, 09:15 AM
  3. relocating drain in a slab floor - concerned about floor
    By yvrtogo in forum Remodel Forum & Blog
    Last Post: 06-11-2010, 11:06 AM
  4. Connect second floor shower drain into first floor kitchen drain
    By lanthoma in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2008, 07:02 AM
  5. 2nd Floor Washer/Waterheater - Overfloor Floor drain tie in.
    By zhomes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-20-2007, 12:30 PM
