Results 1 to 12 of 12
Thread: Installing 12" toilet in 14" rough-in
    DIY Junior Member pos1's Avatar
    Jun 2010
    usa
    Default Installing 12" toilet in 14" rough-in
    I am replacing an existing toilet with a new dual-flush toilet. The rough-in is 14". the toilet I want to install is a 12" rough-in (I'm certain I can't get it in a 14" rough-in). Is the only problem I'll run into cosmetic, in that the tank will sit an add'l 2" from the wall from the existing toilet? it's hard for me to picture what that might look like, but it doesn't seem that big of a deal.
    I have no plans to do any other remodeling, i.e. break the concrete floor, etc. I simply intend on replacing the toilet...I want this to be an easy job. Worst case I'll go shopping for a 14" rough-in toilet, but I'd rather not.
    Any info would be appreciated.
    It will work fine, but as you thought, it will stick out an extra 2" into the room, and from the wall. If that isn't an issue, go for it. It becomes an issue if you have clearance issues. the toilet could sit in the middle of the room, if you liked the look. There are LOTS of toilets installed that have a larger than design gap behind them.
    Any 12" toilet will work for a 14" rough.
    If you want to pull the bowl back 2", then there is only one method.
    Moving the bowl back 2" information
    James demonstrating in an old Seattle home that has a 14" rough-in.
    The toilet on the left is a Toto Soiree with 14" Unift, the toilet on the right, is a Cadet 3 elongated bowl.
    Both bowls are elongated, but you can see how much leg room is gained by James on the Toto. Several inches!
    It's also much easier to use when standing up. His butt doesn't hit the pedestal anymore.
    Same bathroom, different bowls.
    Jun 2010
    usa
    Is it true that the toilet itself will also stick out an extra 2" or will there only be the extra 2" gap between the tank and the wall? I hadn't thought about the toilet actually sticking out more. I guess I had figured that the 14" offset was for toilets that were larger in the tank area (for some odd reason). I think what you're saying is that it's really just the mounting holes on the toilet that are different and therefore putting in a 12" rough-in toilet would move the entire toilet from the wall 2". If so, I may have to rethink this and just go with a 14" toilet.
    Nov 2009
    VA
    It depends on the toilet. Many 14" models are really just a 12" bowl with a thicker tank to make up the space between the toilet and the wall. If you got a Toto with a unifit like Terry mentions, the toilet will move back 2" (closing the gap at the wall and giving you an extra 2" in front of the toilet). If you have a smaller bathroom, using the unifit setup will really help.
    A 12" rough-in toilet sitting on a 14" actual flange, WILL stick out 2" more than the spec sheet says. Now, as Terry linked to, the only one that actually can pull the whole toilet back to the 'design' gap behind is Toto with their UniFit adapter (which only works on some of their toilets, all of them skirted). Most other manufacturers just substitue a different tank to fill the gap, but the front of the toilet from the bolts on the flange to the front remains the same...so, move them out 2", the front has to move 2" as well.
    DIY Junior Member Noname's Avatar
    Oct 2013
    nj
    Default 14" rough-in flange setting and 12" toilet
    I have an older cast iron flange set at 14" from the wall and a 12" toilet - leaving me 4" from the wall. Is there any type of flange or fixture I can get to move the toilet closer to the wall. I have seen offset closet flanges but there is already a flange (cast iron) in the floor. Am I doomed to buying a new 14" rough in toilet? Thanks
    If you want to make the gap smaller behind the toilet, you need to do one of two things: move the flange and downpipe, or buy a toilet designed for a 14" rough-in. If you want the toilet to not stick out as far, then you should look at one of the Toto toilets that use the Unifit adapter (unique to certain Toto toilets). This allows the same toilet to fit on either 10, 12, or 14" rough-ins by changing out the adapter. I think there may be a Caroma brand model that may have some adjustment, but am not certain. The vast majority of other 14" rough-in toilets use the same bowl, and just put a thicker tank on it, so they stick out that extra 2" into the room.
    These days many 14" toilets use a 12" bowl with a tank that is 2" deeper so it comes out closer to the wall. Some 10" toilets do the same with a thinner tank.
    Yakima WA
    Toto is the only manufacturer that makes adapters that will allow some of their models to fit a 10", 12", or 14" rough-in by just selecting the size adapter necessary. The toilet will set in the same place on the floor. The Unifit adapter only works on specific models of Toto toilets and will not fit other makes.
    Jan 2008
    Another alternative that fewer people consider is furring the wall out to take up the space. While this is entirely feasable, if the bath is already small you would be making it that much smaller.
    Yakima WA
    Not to start a war, but while furring the wall out would make the 12" toilet appear to fit better, it would cost as much to do it as getting a Toto with a Unifit adapter, and you'd still have the expense of buying a toilet.
  1. 11" rough in??? Do I get 10" toilet or is there another option
    By PabNYC in forum Toilet Forum discussions
    Last Post: 04-09-2011, 12:03 PM
  2. Best flushing toilet for 10" rough-in? TOTO 10" Drake
    By catorgs in forum Toilet Forum discussions
    Last Post: 11-01-2010, 12:12 AM
  3. Best Toilet for 10" Rough-in, approximately 25-26" length?
    By Danalynn in forum Toilet Forum discussions
    Last Post: 09-22-2009, 10:23 AM
  4. One toilet 12" Rough-in, other 2 are 13.5"
    By J_Tay1981 in forum Toilet Forum discussions
    Last Post: 04-21-2009, 06:58 PM
  5. 12" toilet on a 14" rough in on concrete slab
    By Quinn in forum Toilet Forum discussions
    Last Post: 10-12-2005, 10:39 PM
