Results 1 to 5 of 5
Thread: Shallow well loses prime
    DIY Junior Member porter123's Avatar
    Jun 2010
    Charleston, SC
    Default Shallow well loses prime
    My well loses prime overnight. The pressure gauge stays around 40psi as long as the water is turned off, but as soon as I open the spigot, the pressure drops to zero and I've got an unprimed pump.
    Any ideas where the problem may be? The fact that the pressure tank gauge stays at 40psi suggests there is no leak in that area.
    Moderator valveman's Avatar
    Mar 2006
    You have a leak before the check valve.
    Jun 2010
    Charleston, SC
    Thank you. How do I go about fixing it? You're basically telling me that the leak is underground in the pipe going down to the well, right?
    Mar 2006
    Where is your check valve?
    Jun 2010
    Charleston, SC
    It's about 6 inches above ground level on the vertical pipe going down to the well.
  1. shallow well pump loses prime overnight
    By sailit2000 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-23-2008, 06:32 AM
  2. shallow well jet pump loses prime at 50psi
    By Guido_D2006 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-06-2008, 09:12 AM
  3. Jet Well for Heat Pump loses Prime with Demand
    By joeharley in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-04-2007, 07:31 AM
  4. sandpoint sucks air loses prime
    By tigbarn in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-01-2007, 08:08 AM
  5. shallow well loses prime and no pressure
    By chefallen in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-13-2007, 07:20 AM
