Results 1 to 2 of 2
Thread: Lightning fries hot tub
    DIY Junior Member fband's Avatar
    Jun 2010
    New Haven, Ct.
    Question Lightning fries hot tub
    My hot tub has been hit by lighting several times, even when the disconnect is off. I believe lightning strikes hitting the ground are comming in from the ground rod to the hot tub and blowing the circuit board. What can I do?
    I'd consider a couple of things: a high-quality, wired-in surge suppressor (well, if the tub was actually plugged in, I guess you might be able to use a good plugged in one), and if really paranoid, you could add a properly engineered, grounded pole near the tub to act as a lightning rod. This won't protect from a direct strike, but should resolve near misses and minimize near misses. They provide a cone of protection underneath them - I forget the angle, but the higher it is, the larger the diameter of the protection as that cone intersects the ground. this is what we did to protect things like radars and missile launchers when lightning was a problem (missile sites often ended up on the top of mountains!). Get a surge suppressor with the highest joule rating you can afford, and fast response (the better ones are around 1-nanosecond). To work, generally, it needs to be still connected to the power ground in order to have a path to discharge. The better ones come with a decent insurance policy against damage...just read the fine print to ensure you qualify, and keep whatever materials you need to justify the claim (receipts, etc.).
  1. preventing lightning from traveling up septic pipe
    By mauzbiz in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-07-2009, 12:53 PM
  2. Space Needle Lightning Strikes
    By Cookie in forum Computers and Stuff
    Last Post: 07-09-2009, 02:49 PM
  3. Lightning Storms vs. Grundfos CU 301 Control
    By paxto in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-28-2009, 07:21 PM
  4. Lightning Facts
    By Cass in forum Electrical Forum discussion & Blog
    Last Post: 12-22-2008, 09:22 AM
  5. CSV - Do you want fries with that?
    By Rancher in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-10-2007, 12:54 PM
