Results 1 to 5 of 5
Thread: Can I replace an old Friedrich wall AC unit with a new Frigidaire wall unit?
    DIY Member Pickngrin's Avatar
    Sep 2005
    Massachusetts
    Default Can I replace an old Friedrich wall AC unit with a new Frigidaire wall unit?
    We've got an old Friedrich QuietMaster wall AC unit (I'm guessing about 18K BTU ?) that appears to have kicked the bucket today -- it's not blowing cold air anymore. I've never dealt with wall units before and would like to know if I can replace this unit with any wall unit that has dimensions the same size or smaller than the existing sleeve. Or would this involve having a new sleeve installed?
    Retired prof. engr. gator37's Avatar
    Nov 2009
    Alabama
    Recommend that you check the amp draw, voltage, and recommended fuse size before you purchase. Don't know if you have a heatpump with aux heat strips or no aux. electric heat, staignt cool with no heat or straight cool with heat.
    The sleeve size would have to be your call.
    The other main thing is that the new HVAC cabinet will fit in your existing wall sleeve.
    Friedrich still makes wall units, and probably has a line that is an exact match for your sleeve. Friedrich is a solid brand in air conditioners, Frigidaire is probably made by the lowest bidder in china. I have found frigidaire quality to be average at best.
    Sep 2005
    Massachusetts
    Thanks. I looked further into this today, and unfortunately there is no exact fit for my old unit (SL19H30), as they have apparently reduced the size of the chassis. Apparently, there is no good solution to this problem. I was ready to spring for a new Friedrich until I found out that it is not an exact fit.
    The question becomes whether it is easier to make the opening larger or fill in the gap to use a smaller unit. Sometimes you may have to do both if the width and height make it necessary.
  1. need opinion of what to do on the wall above shower unit
    By czexrus in forum Shower & bathtub Forum & Blog
    Last Post: 02-21-2010, 03:25 AM
  2. Best way to reattach glass door unit to fiberglass shower wall?
    By nightowl in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2009, 06:04 PM
  3. wall unit AC question
    By chaoster in forum HVAC Heating & Cooling
    Last Post: 05-11-2008, 11:04 AM
  4. sterling bathtub/wall surround unit-HELP
    By kdarcy in forum Shower & bathtub Forum & Blog
    Last Post: 10-09-2007, 01:30 PM
  5. looking for a self contained plumbing wall unit for shower and bathtub
    By jeanne in forum Plumbing Forum Discussion & Blog
    Last Post: 07-20-2006, 10:15 PM
