Results 1 to 5 of 5
Thread: photocell light
    DIY Junior Member hidden 1's Avatar
    Mar 2009
    TN
    Default photocell light
    i have a outside light that uses a large sodium bulb with a photocell.comes on at dark off at dusk.i changed the photocell a year ago w no problems ,but lately it has been off and breaker tripped as i come home .reset it then 2 days later breaker tripped- back on all night after reset.-is this a sign the photocell is going out?in the last 5 years i have never had a problem ,always working.
    any suggestions?
    Nov 2006
    I have the same light, and its photocell is simply a switch in the circuit of the fixture tripping your breaker. I would suspect your breaker is weak and no longer able to supply the light.
    Plumber jimbo's Avatar
    HPS bulbs have a feature called end-of-life cycling. They will be on for a while, go off for a while, back on , etc. This should not trip a breaker. I would just take out the photocell to rule that out, and if the problem persists, replace the bulb, and finally the ballast.
    Usually parts for a light such as this cost more than a completely new fixture. There are several things which could cause the breaker to trip. A loose connection at the breaker, a bad ballast, etc., but the photo cell should NOT be able to trip it, unless its circuitry is shorting out periodically.
    Mar 2009
    TN
    I had a feeling it could be ballast since its got a louder of a buzz after the reset of fuse .
    I may just replace light .I dont think the sodium bulb can factor in on the louder buzzing than usual.
  1. DIY - Split receptacle to light switch and light fixture with 14/2?
    By AJM in forum Electrical Forum discussion & Blog
    Last Post: 11-24-2009, 04:36 PM
  2. Lamp post photocell hook up
    By mr fix it in forum Electrical Forum discussion & Blog
    Last Post: 11-17-2009, 04:17 PM
  3. Outside Light
    By white tiger in forum Electrical Forum discussion & Blog
    Last Post: 11-14-2008, 10:45 AM
  4. pilot light wont stay light on furnace
    By possum in forum HVAC Heating & Cooling
    Last Post: 10-07-2008, 12:48 PM
  5. photocell + CFL don't play well with DSL
    By drewc in forum Electrical Forum discussion & Blog
    Last Post: 04-23-2008, 07:39 AM
