Results 1 to 3 of 3
Thread: Leaking Delta bathrub spout
    DIY Junior Member bsptpc's Avatar
    Jun 2010
    Dallas
    Default Leaking Delta bathrub spout
    Hello and thanks in advance for any assistance offered.
    I have a leaking bathtub spout. It's a whirlpool type tub. It has a spout and two separate knobs for hot and cold. The spout and knobs are on top of the tub...not in the walls of the tub.
    It is leaking hot water.
    I removed the hot water knob....and there looks to be a hard pipe stem with a plastic part inset into it.
    Any idea how to remove the plastic part?
    Thanks in advance,
    Chris
    Here is a good video showing how to repair it.
    http://www.deltafaucet.com/videogall...eatsAndSprings
    Your faucet has the seat and spring like in the video, but only one below each handle.
    The brass nut holds the stem in.
    You can also find replacement stems.
    The video shows a single handle repair, but it should be enough to show the spring and seal that needs replacing.
    Jun 2010
    Dallas
    Thank you very much!
    Chris
  1. Delta 2 handle bath faucet (3555) - leaking from under spout body
    By PeteD in forum Plumbing Forum Discussion & Blog
    Last Post: 06-11-2010, 08:09 AM
  2. Delta Tub Spout Stub Length
    By Jeff_08 in forum Shower & bathtub Forum & Blog
    Last Post: 04-09-2008, 03:03 PM
  3. Removing old Delta spout / diverter
    By billwil in forum Shower & bathtub Forum & Blog
    Last Post: 09-10-2007, 07:11 PM
  4. Removing Delta tub spout
    By SWB in forum Shower & bathtub Forum & Blog
    Last Post: 01-26-2006, 08:52 AM
  5. Delta tub spout leaking
    By tameria11 in forum Shower & bathtub Forum & Blog
    Last Post: 10-08-2005, 08:01 AM
