Results 1 to 3 of 3
Thread: Ground wire confusion
Hybrid View
    DIY Junior Member a12548's Avatar
    Jul 2006
    Florida
    Default Ground wire confusion
    I re-sided my home and will reattach the ground wires back to house. Can I group all 3 ground wires together on clips? Can I use the regular plastic cable clips? They all lead to the hose bib, and they are attached with straps that tighten with a screw. Im replacing hose bib, does Home Depot sell those straps?
    Also my new air conditioner seems to have an old ground wire which is loosely clamped to a line coming out of house then leads to just a ground block mounted on the house that ends there, nothing attached to it. I suspect its left over from my old unit, how are units such as Goodman grounded?
    DIY Member Lightwave's Avatar
    Aug 2007
    Vancouver, BC
    From your description it doesn't sound like your grounding is code compliant or particularly safe. House ground wires must be connected to a good quality ground connection--a hose bib doesn't count. At minimum, you'll need a ground rod.
    Ask your local electrical inspector what the code requirements are in your area for grounding.
    What size are the wires? That connection sounds like an old telephone ground line.
  1. Need to add ground wire
    By rayh78 in forum Electrical Forum discussion & Blog
    Last Post: 11-03-2009, 04:03 PM
  2. Does a ground wire nut need to be in a box?
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 09-26-2009, 08:33 AM
  3. Ground wire
    By kregas in forum Electrical Forum discussion & Blog
    Last Post: 10-27-2008, 05:56 PM
  4. Ground Wire???
    By Fuoti in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-24-2008, 07:43 AM
  5. Pump Ground Wire
    By bobabuoy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-01-2006, 11:35 AM
