Results 1 to 2 of 2
Thread: Kitchen hot water pressure
    DIY Junior Member
    Sep 2009
    Wichita, KS
    Default Kitchen hot water pressure
    We relocated our hot water heater today for some remodeling. All of the bathroom faucets/tubs are working fine, but the kitchen hot water is only coming out at a trickle. Cold water is fine. The faucet is a Grohe Ladylux, and I have checked the usual suspect filter on that.
    The kitchen is the furthest water source in the house from the HWH, and the HWH has a recirculating line attached, if that matters. We switched from very hard well water to city water a few months ago, and are thinking about going with a tankless HWH when this one goes out/remodel is finished. The current tank is about 7 yrs old, though I doubt that has anything to do with it, as other hot water sources are working fine.
    Thanks for your help.
    You probably dislodged some crud in the lines and it is clogged up. Not sure of the best way to try to clear it out. Have you tried calling Grohe for any suggestions? If you take the hot water supply line off, have you verified you get good flow out of the stop at the wall?
  1. no water pressure in kitchen
    By LM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-02-2008, 02:25 PM
  2. Low Pressure in Kitchen
    By Maya in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2008, 10:23 AM
  3. Need advice re Kitchen Water Pressure
    By shlittle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2007, 01:03 PM
  4. Low pressure at kitchen sink
    By Jerry S. in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2006, 11:45 AM
  5. Kitchen sink hot water pressure
    By jmw835 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-05-2006, 02:28 PM
