Results 1 to 8 of 8
Thread: Updating exsisting plumbing
    DIY Junior Member naglejob's Avatar
    Jun 2010
    pittsburgh, pa
    Default Updating exsisting plumbing
    hello,
    i recently purchased a home. While doing some concrete work in the basement i started to notice a sewer gas smell coming from my drain in the garage. I decided that since i was doing concrete work i would dig up the drain and see exactly what was going on. It turns out that 40 years ago when they built an addition onto my house the built it over the main line trap ( which is normally outside?) and the drain was an open vent to my trap. I talked to a plumber and he thought it would be alright if i just capped it off but then i would lose my garage floor drain, but if i put a trap on top of the trap i would lose my access for snaking my main.... so i am not sure what to do. Also i wanted to replace some of the floor drains in my house and noticed they are all of the bell trap design. If i change them to p traps i am afraid of the problems that might arise from ventilation. Any suggestions?
    Jan 2008
    In some areas floor drains in garages are no longer permitted unless there is an oil/water separator installed.
    Before you change anything I recommend checking with your building inspector.
    Jun 2010
    pittsburgh, pa
    Good call, never even considered that one. What about the bell traps?
    They have been outlawed for decades. Just changing to "P" traps will NOT change the "ventilation", other than the bell traps were probably not working anyway. There are ways to keep the access to the house trap, (although I, and many other plumbers, would remove the trap IMMEDIATELY), and still connect a floor drain to it.
    Jun 2010
    pittsburgh, pa
    I don't think I can remove the main trap, I would have to relocate it outside, and that would get expensive.
    You're missing the point about the main trap...most systems do not have one at all...it's not an issue with relocating it, it's eliminating it altogether. It's an impediment to good flow and a likely problem if you do need to run an auger through the lines.
    Jun 2010
    pittsburgh, pa
    I believe the main trap is required in Pittsburgh by code
    Jun 2010
    pittsburgh, pa
    talked to a plumber, his suggestions are 1. cap off the drain temporarily to see if my system functions properly
    2. If everythings good just install a finish grade cap and close it up
    ( if i was going to add another floor drain i would have to move my main trap outside, this would involve ripping up my driveway cost hundreds...)
    He also said the floor drains in the house could be changed over to p traps and if they don't already have traps hooked to them, this would cause no problems
    Thanks for all the help Terry!
  1. Updating shower in basement
    By 87GNat in forum Shower & bathtub Forum & Blog
    Last Post: 01-09-2010, 01:12 PM
  2. Updating shower trim
    By ras1050 in forum Shower & bathtub Forum & Blog
    Last Post: 01-08-2010, 09:44 AM
  3. Help Updating Basement Plumbing Drains
    By djmed in forum Remodel Forum & Blog
    Last Post: 01-12-2009, 08:10 AM
  4. Updating Very Old System Timer
    By sobersgea in forum Irrigation / Sprinkler Forum
    Last Post: 05-24-2008, 04:05 PM
  5. need advice on updating boiler system
    By IleanasColors in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2007, 07:16 AM
