Results 1 to 6 of 6
Thread: relocating drain in a slab floor - concerned about floor
    DIY Junior Member yvrtogo's Avatar
    Jun 2010
    Vancouver, BC
    Default relocating drain in a slab floor - concerned about floor
    We want to relocate our washer/dryer about 10 ft from its original location. We have a slab floor, so re-routing the drain would mean digging a trench in the slab floor to run the new drain pipe.
    My concern is the cutting up the slab floor part - all the plumbers I've talked to have no issue with it, but I'm concerned for my foundation. Would cutting into the slab affect the foundation? The house is ~ 35-40 yrs old - and so far the foundation & slab are in great condition.
    Any suggestions to allay my fears would be welcome.
    it is the way we do it all the time. we do it with jackhammers and sledge hammers and never damage anything
    Normally not a problem. But, if your house is built using a post-tensioned slab...big problems. Post-tensioned slabs have steel cables embedded in them that are terminated in a threaded connection and they are tightened after the slab is poured. They help in earthquake country and on less than ideal soil conditions to keep things from cracking. Cutting through one of those cables can be very dangerous.
    Post tensioned is not likely in a 40 year old home, as far as I know.
    The least amount of damage would be a wet saw contractor. They use a diamond blade cooled with a stream of water so there is no dust.
    Since the slab is cut and not hammered, it stays more intact. Also pouring new concrete back is easier.
    If you go "old school" and use a jackhammer, turn off the forced air heat.
    When those things kick on it can spread concrete dust all over the house.
    Nov 2009
    VA
    I agree with using a wet saw. The water is still a bit messy, but will control the dust. I dry cut my slab with a diamond blade, but the dust goes everywhere. It gets so bad, that you have to stop often as the dust is so thick, you can't see what you are doing (covers the goggles too). I made sure that the HVAC was off and tried to close off the area to the rest of the house and open windows to let the dust escape, but dust still went everywhere. Even the 2nd floor (with the slab being cut in the basement) saw significant dust.
    You can save some $$ doing it yourself, but prepared to be cleaning everything in your house for some time.
  1. Slab floor drain leak
    By chas22 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-28-2009, 05:16 PM
  2. Easiest way to deal with a corroded drain at floor slab?
    By SmallSea in forum Plumbing Forum Discussion & Blog
    Last Post: 10-21-2007, 06:30 AM
  3. I need to add post-slab floor drain
    By Javanut in forum Plumbing Forum Discussion & Blog
    Last Post: 01-29-2007, 11:18 AM
  4. Washer Drain - Relocating to 2nd Floor Closet
    By shoo fly in forum Plumbing Forum Discussion & Blog
    Last Post: 12-06-2006, 08:40 AM
  5. Floor Drain In Slab Foundation????
    By ironwmnmk in forum Plumbing Forum Discussion & Blog
    Last Post: 11-08-2005, 07:11 PM
