Sounds like the valve is in need of a rebuild; a loose part inside of it is most likely the cause of your problem. Contact the mfg of your valve or contact a local plumbing supply to get the parts you need. If you haven't rebuilt a faucet before it might be worth viewing a PDF file on the mfg. website to know how to take it apart and put it back together.
