Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Panel supply cable
    Engineering Technician The old college try's Avatar
    Jan 2007
    MO
    Default Panel supply cable
    I'm getting ready to replace my panel in the near future and I have a few things I'm still trying to figure out. From the picture can anyone tell me if it's ok to have the supply cable sweep down like it currently does into the panel, or will it need to be protected in conduit or something? Same thing for the large cable (#6?) that runs down beside the panel and enters through the bottom. Any concerns?
    I am not sure about these days, but back in the "old days" if a wire could be damaged it had to be enclosed/protected somehow. That wiring job looks like "Topsy", it just grew and kept growing whenever a new wire was needed.
    Jan 2008
    I wouldn't feel real comfortable changing that water filter there either.
    Jan 2007
    MO
    Yeah, it's an 80 year old house, so it seems that every previous owner jacked things up more and more and time went on. I've had to fix alot of problems over the last 5 years.
    Jan 2007
    MO
    Well, I made a new discovery. I went out to look at the meter to see what size of conduit the cable is enclosed in. To my surprise, the cable down to the meter is in conduit, however the cable leading down from the meter along the exterior wall is not protected in conduit. It's exactly as seen in the picture, except one of the previous owners decided to paint over it. It just enters the house through a hole that's loaded with caulk. I guess I never really noticed since it's painted. Great.. there's another cost. Was this to code at some point?
    Jun 2007
    NY State, USA
    WHY????
    Will the mean electricity jump out of the closed panel and sealed wiring, and grab you while you are all soaking wet from chaning a simple water filter?
    Answers based on the 2008 & 2011 NEC. If you're on the '14 already I feel sorry for you.
    Jun 2007
    NY State, USA
    Quote Originally Posted by The old college try View Post
    Absolutely yes. In most areas this is perfectly FINE.
    If it is conduit on the top side is it a mast that goes through the roof?
    Jan 2007
    MO
    Quote Originally Posted by Speedy Petey View Post
    So, can I just leave it as is? Also if it's exposed on the outside where it can get hit by weed wackers and stuff, is it really that bad to have exposed in the house, or should I still try to enclose it?
    Yes. The conduit runs up through the soffit to a mast about 2 feet above the roof where it then goes to the pole.
    Nov 2009
    VA
    Exposed SE cable is really common around here. On my house, it is exposed after the mast (mast to meter and meter to panel).
    Jun 2007
    NY State, USA
    If it is truly subject to physical damage it should be covered or sleeved. 90% of the time it is left exposed around here.
    This is a mast service. Then the metal conduit is not to protect the wire, it is for structural support of the overhead drop.
    Jan 2007
    MO
    Ok, well considering all that, do you suggest that I do anything with the cable, or just leave as is and run to the new panel?
    DIY Member bsperr's Avatar
    Apr 2008
    Athens, GA
    You may want to check with your electrical inspector on how farthey'll allow you to run your service conductor into the home without over-current protection. You may have to install a disconnect outside if you don't already have one.
    Jan 2007
    MO
    ng
    Quote Originally Posted by bsperr View Post
    Hmm. I suppose I'll have to make a list of questions for him. The panel is really only 3 feet from where it enters my house. Is that really a long distance compared to what would be 'typically' acceptable? If I end up running a new cable from the meter to go in through the top of the panel, would it be better to make the horizontal run along the inside or outside of the house. Secondly, is there an advantage to going with 2/0 copper over 4/0 aluminum? The price difference really isn't much for the 10 feet that I'll need... maybe $15 at most.
    Apr 2008
    Athens, GA
    ng
    Hopefully your inspector will let you go three feet without overcurrent protection, but I think you should check just to be sure. My inspector interprets the "nearest the point of entry" language in the NEC to mean immediately, so we have to have a disconnect unless the meter pan and breaker panel are back-to-back, so that the service conductors are just in one stud bay. I used 4/0 AL SER for my service upgrade. I think that copper would be easier to work with, but the AL wasn't that bad
    Jun 2007
    NY State, USA
    Not at all. Typically 5'-6' is the range of distance for this.
    Only about 10% of places require an outside disconnect, and this is typically in the southwest.
    It's worth asking I guess, but if there is not one now chances are you do not need to install one.
  1. Using just a screwdriver to change out a 100 amp main panel to a new 200 amp panel
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 05-19-2010, 06:08 AM
  2. Cable V
    By Barry J in forum Computers and Stuff
    Last Post: 02-19-2010, 07:20 PM
  3. Cable or Jet?
    By Nate R in forum Drain Cleaning
    Last Post: 01-09-2010, 07:01 AM
  4. No 6 AWG Cable
    By devans175 in forum Electrical Forum discussion & Blog
    Last Post: 09-12-2009, 06:33 PM
  5. Cable Drain (long cable needed)
    By dick2222 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2009, 07:03 PM
