Results 1 to 5 of 5
Thread: City boy moves to the country.
    DIY Junior Member Rick29's Avatar
    Jun 2010
    Paulding Ohio
    Default City boy moves to the country.
    Sirs,
    I am buying an modular that sits in the country on 4 acres, and has a well and septic system. The modular has been empty for two years and was built in 1982. I was wondering what I need to do to restart the water system? It has been winterized. I have found two water lines unhooked. So other than hooking up those water lines, what should I do?
    Moderator valveman's Avatar
    Mar 2006
    Jet pump, submersible pump? Where do the two lines come from?
    Jun 2010
    Paulding Ohio
    Sir,
    Outside, there is a lined hole with wiring above the hole with a cover, I am thinking the pump is in the hole. Inside the house there is a tank, looks something like the one in the picture in your answer and it goes to a water softener. I noticed that under one of the sinks the water lines were unhooked. I know that I will have to hook them back up. Also there is a new water heater in the house and it fells empty.
    Uploading pictures of the area and the hole with the cover will help a lot. Or at least tell us some dimensions, is the hole 3" or 3'. How many wires or strands? Colors of the wires. Where do they come from and go to?
    28 years old and unoccupied for 2 years? There are many POSSIBLE problems, but maybe none that you have to worry about. All you can do it reconnect the piping, and then energize it to see what happens.
  1. NEW to the country and a well!! NO CLUE!!!HELP
    By pestario76 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-06-2010, 06:12 AM
  2. City Girl in the country with a well...
    By luvnaz in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-06-2009, 05:13 AM
  3. Toilet moves around
    By John H. Power in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-05-2008, 03:41 PM
  4. Country of origin for pipe and tubing?
    By scrunchielaura in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2008, 11:05 PM
  5. City girl needs help with country well/pump
    By ScotDeerie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-11-2007, 06:36 AM
