Thread: Bathtub Outlet Nozzle Too Short!
    DIY Junior Member bl's Avatar
    Jun 2010
    Livermore nj
    Default Bathtub Outlet Nozzle Too Short!
    Hi!
    I'm remodeling my bathroom and am installing a different bathtub (36" Jacuzzi whirlpool tub). My problem is that due to the design of the new tub, the new spout (for the water outlet) does not extend far enough from the wall for the water to pour directly into the tub. Instead it will hit a portion of the tub's top and spray everywhere. The spout is about 5" and I need it to be about 7" in order for the water to clear the top of the tub and fill it properly without spraying. The tub/shower walls will be tiled.
    Any ideas on how to resolve this would be greatly appreciated!
    Bill
    Jan 2006
    Rosedale, Md
    Go to plumbing supply.com they have 7in. you'll have to cut and paste, I don't know how to add a link.
    There are lots of spouts in all sorts of lengths, styles, and finishes...you just need to do a search, and open your wallet - the longer, high style ones can get expensive.
    To make things easier, you first need to determine how yours is attached. They come in two general forms: screw-on, push-on. A push-on one will have a notch for a set screw to hold it in place and keep it from rotating or pulling off. A screw on one may have a little notch on the bottom to allow trapped moisture to drain, but no screw hole.
  1. Replies: 9
    Last Post: 12-11-2012, 12:01 PM
  2. Pump is short cycling.....Very short!!
    By crittercatcher in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-29-2009, 09:26 AM
  3. Jet Pump venturi/nozzle selection
    By toolfool in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-21-2008, 07:29 PM
  4. broken shower nozzle arm
    By danbbbb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-16-2008, 07:47 PM
  5. Single handle, pull out nozzle kitchen faucets
    By Puzzled in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-01-2007, 06:58 AM
