Results 1 to 3 of 3
Thread: Grounded Armored Cable?
    DIY Junior Member onestepahead's Avatar
    Jun 2010
    NJ
    Default Grounded Armored Cable?
    Hello-
    My house is over 70 years old. Wired with armored (BX) cable - cloth wrapped hot & neutral inside. No ground wire.
    I've been gradually replacing ancient receptacles with 3-prong ones. I've been pigtailing the ground screw to the metal outlet boxes. I've been testing each box with with a voltage tester (one of those little ones that's just a small light), and I've since acquired one with a digital readout for the last few. Indeed, I'm seeing the same voltage (~124v) from hot to neutral as hot to ground - indicating (i think) that the boxes, via the armored cable, are grounded.
    However, I've recently read some postings claiming that armored cable doesn't provide true ground - that there is so much conductive material joined by the boxes and all of the cable sheathing that current will flow into it, but that there still may be a more direct path to ground in the event of a short circuit.
    so, is that true?
    I have no way to measure the current, only the voltage. Do I have a grounded system?
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    This is very true.
    The problem is not that of finding a different path, it's one that a fault will follow the spiral of the sheathing and not run along it in a linear path. This creates very high resistance and can cause the sheathing to be a heating element instead of a fault current conductor.
    Modern AC cable (~1960's on) has a thin bonding strip that "joins" all the spiral coils and lats fault current flow directly down the cable.
    Answers based on the 2008 & 2011 NEC. If you're on the '14 already I feel sorry for you.
    DIY Junior Member partimer 31's Avatar
    Jun 2010
    Manchester, Vermont
    Speedy Petey answer was very good. I would just add, If the amored cable is not a good grounding conductor, install GFCI duplex receptacles. This is an opinion on mine. Replacing the old BX cable is better, if you have the funds to do this.??
  1. Cable V
    By Barry J in forum Computers and Stuff
    Last Post: 02-19-2010, 07:20 PM
  2. Cable or Jet?
    By Nate R in forum Drain Cleaning
    Last Post: 01-09-2010, 07:01 AM
  3. No 6 AWG Cable
    By devans175 in forum Electrical Forum discussion & Blog
    Last Post: 09-12-2009, 06:33 PM
  4. Cable Drain (long cable needed)
    By dick2222 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2009, 07:03 PM
  5. improperly grounded panel?
    By Bob in Maine in forum Electrical Forum discussion & Blog
    Last Post: 07-08-2008, 07:02 AM
