Results 1 to 8 of 8
Thread: Brine Tank Safety float setting
    DIY Member farmboy101's Avatar
    Apr 2010
    Vancouver Island
    Default Brine Tank Safety float setting
    I am curious to know if the lower o ring needs to be set somewhere on the shaft. The upper one needs to be set so its just below the overflow fitting but the lower one was set on the bottom of the shaft. The float moves up and down freely but should the float rest at the bottom of the shaft and rise up and down with the water level or should it be set higher up so it only hits the top o ring in the event of a malfunction??Name:  Brine Float 002.jpg
Size:  22.6 KBName:  Brine Float 003.jpg
Size:  24.1 KBName:  Brine Float 001.jpg
Size:  32.9 KBName:  Brine Float 004.jpg
    Dec 2009
    Alaska
    Shoot the thing now before the headaches start....
    When I come across this kind of float assembly I put in a request to change it out with the 2310 safety float assembly as I have had next to no problems that 2310 plastic or brass.
    Yes brass fell to the salt air but out side of that challenge .. no problems.
    The one that you have has in my view to many things to go wrong and be a real pain ...
    Apr 2010
    Vancouver Island
    Quote Originally Posted by Akpsdvan View Post
    Curious to know what part is crap? All of it ?
    Dec 2009
    Alaska
    The bottom part has its challenges, some times not seating right. If there is some salt or any thing else that gets in and around that rubber disk that can cause it not to work right.
    The float rod can be a challenge, if there is a problem with it not filling trying to push down on the whole assembly could break the rod as it is of a plastic ..
    It is much like the cheap Sears GE softener float... if any thing goes wrong they have made it cheaper to replace than fix.
    Apr 2010
    Vancouver Island
    OK, I will look for a 2310 but will have to use this until then. I thought it was kinda frail looking when I took it out. Thanks
    Dec 2009
    Alaska
    There is a site that we all know that people buy and sell.....
    180502635225
    is a lead as to the type that I am talking about.
    Apr 2010
    Vancouver Island
    Thumbs up
    180502635225
    Thanks Akpsdvan, I never even thought about looking there
    Dec 2009
    Alaska
    That name is kind of like the Dark Lord who's name we do not speak of.....
  1. Pre or Post Brine Tank Fill
    By statin in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-01-2009, 08:17 AM
  2. kenmore flooded brine tank HELP!
    By Kenbow in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-09-2009, 03:24 PM
  3. Brine Tank Question
    By Truckman in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-20-2009, 09:58 PM
  4. Float in water tank
    By DryCalifornian in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-09-2008, 07:39 PM
  5. safety valve: hotwater tank, test if bad ?
    By w1ljm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2006, 06:29 PM
