Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Subfloor thickness
  1. #16
    DIY Senior Member ingeborgdot's Avatar
    Mar 2008
    Kansas
    What size screws do you recommend into the 3/4 bottom layer I am now putting on? It will be going directly into the joists.
  2. #17
    A 2" screw would be fine. Something like this would work. http://www.dhcsupplies.com/store/p/2...s-2-to-3-.html I like square drive since the bit wedges tighter if you push, and doesn't cam out like a typical phillips head. Do use some good construction adhesive on the joists. Then, the screws are there as clamps, almost irrelevant after the glue sets, but do add some strength.
  3. #18
    Mar 2008
    Kansas
    I ended up taking out the crappy 1/2" plywood and have replace it with some nice 3/4"stuff. It has nine layers and both sides are usable. I told them I wanted the strongest stuff they had and they sold it to me. What next? Radiant, thinset, ditra, thinset, and then tile? Or 1/2" ply and then radiant, thinset, ditra, and then thinset and tile? Anyone?
    I also sistered the joists and most of them I got about 70% of the joist sistered. Some were more than 80% and some were less than70%.
  1. Thinset Thickness
    By cjt in forum Shower & bathtub Forum & Blog
    Last Post: 12-04-2013, 07:25 AM
  2. different tile thickness' what to do?
    By chris fox in forum Remodel Forum & Blog
    Last Post: 11-03-2007, 09:53 PM
  3. fiberglass thickness
    By lindalawson in forum Shower & bathtub Forum & Blog
    Last Post: 10-03-2007, 10:08 PM
  4. Swanstone Panel Thickness?
    By elgato in forum Shower & bathtub Forum & Blog
    Last Post: 06-10-2007, 08:28 PM
  5. Subfloor thickness
    By Jedi in forum Remodel Forum & Blog
    Last Post: 04-19-2007, 05:53 AM
