I understand you have made no changes to the programming. I suggest you check through the programming and confirm that it is as you originally set it.
Regeneration every day would occur if day override is set to 1.
If the programming is incorrect I suggest you correct it and see if the problem reoccurs. If it does probably have a defective circuit board.
) and furthermore if there is a warranty issue I send it back and get a new one. No questions asked. No screwing around. The customer gets a whole new unit not something that someone has hacked on.
