Results 1 to 11 of 11
Thread: outside shower hookup to house supply
Hybrid View
    DIY Junior Member rxnet's Avatar
    Jun 2010
    south jersey
    Default outside shower hookup to house supply
    Trying to get suggestions on hooking up an outdoor shower with hot/cold supply lines. The shower has 1/2 inch MIPS and the current supply lines are standard 1/2" copper. My design was to use stainless flex supply lines from the shower through the wall and into the crawl space attaching to CPVC lines with shutoff valves and from there tie into the copper house supply lines using compression T's. In the winter, this would allow me to shut off the water supply to the shower, unscrew the stainless supply lines under the house , and pull off the shower head to store for the winter. (the shower head is 4ft wall mounted). If this would work , I'm not sure which fittings and what size fittings,pipe, adapters,valves, etc.. I would need to complete the run from the compression T to the 1/2" shower MIPS. any help would be greatly appreciated!!!
    walt
    Jun 2010
    south jersey
    would this work (I'm trying to avoid soldering) shower 1/2 mips > 30" 1/2"FIPS x 1/2" FIPS stainless steel flex connector > (metal male adapter) 1/2" MIPS Brass with 1/2" CPVC slip > 1/2" CPVC pipe > 1/2" CPVC ball valve > 1/2" CPVC pipe > (metal male adapter) 1/2" CPVC slip with 1/2" MIPS brass > 1/2" Reg female adapter 1/2" FIPS x C > compression T > supply lines 1/2" copper tubing ??
    Jun 2009
    Penticton, BC
    Quote Originally Posted by rxnet View Post
    We like pictures....
    Jun 2010
    south jersey
    Default pics
    here are the pics...stainless flex > cpvc/brass fitting > 1/2" CPVC > ball valve > 1/2 cPVC > cpvc/brass fitting > copper fitting > compression T
    DIY Member wallskev's Avatar
    May 2009
    North Carolina,USA
    Lightbulb Double Vlave less prone to issues
    I have a outdoor shower system that drains etc and feel it would be better not to use the Braided Flex and have to disconnect them etc.
    1. Use Pex in place of CPVC, easer and less trouble
    2. Utize a Double Drain Valve system, 1 to shut off flow and 1 to use as Drain.
    I use ball valves and have my drain do direct to a sump . Keep a pitch on the lines from the "T" connection to the Shower Vlaves and you will alwas have a good winter drain.
    Kevin
    Kevin
    Jun 2010
    south jersey
    kevin
    are the chances pretty small that the pex would freeze between the main and first ball valve with that set-up?
    Jun 2009
    Penticton, BC
    Ummmm I meant pictures of where you want to install this stuff... not of the fittings.
  1. What kind of toilet supply hookup is this?
    By JimR1998 in forum Toilet Forum discussions
    Last Post: 07-10-2009, 10:49 AM
  2. Home Depot or supply house ???
    By 10"rough in forum Toilet Forum discussions
    Last Post: 04-25-2009, 05:47 AM
  3. Experience with plumbing supply house
    By SteveW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-25-2006, 07:13 AM
  4. Plumbing Supply House
    By Linc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-01-2006, 06:39 PM
  5. Shower faucet hookup
    By not my day job in forum Shower & bathtub Forum & Blog
    Last Post: 08-06-2005, 07:03 AM
