Thread: trap primer for the floor drain, Canada
    DIY Junior Member simmy1919's Avatar
    Jun 2010
    Niagara Falls
    Default trap primer for the floor drain, Canada
    My laundry sink has a trap primer for the floor drain that runs as a line from under the faucets. Lately, I've noticed a constant trickle of hot water running through the line, even when the faucet is off. There is a distinct noise coming from the copper pipe that leads to the faucet that was not audible before. Is the constant trickle normal and/or is the noise a problem waiting to happen? Thanks for any help.
    Jan 2006
    Rosedale, Md
    If you have a mechanical trap primer that keeps running it's almost certain that it's defective, if you get hot water down the drain it's hooked up backwards; need to be replaced.
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    Quote Originally Posted by simmy1919 View Post
    Replace the hot water washer on the tap and the trickle will stop. While your at it , replace the cold water washer too.
    95% of Canadians rarely use mechanical trap primers because they are prone to fail.This particular set up is attached to the laundry tub faucet
  1. floor drain, Canada
    By christoff in forum Canadian Plumbing Code Questions
    Last Post: 06-20-2010, 04:48 AM
  2. floor drain, Canada
    By christoff in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  3. Laundry drain pipe help for s-trap location. Canada
    By klrman in forum Canadian Plumbing Code Questions
    Last Post: 06-03-2010, 02:40 PM
  4. Laundry drain pipe help for s-trap location, Canada
    By klrman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. Trap primer needed on unused floor drain?
    By karsc01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-02-2006, 09:11 AM
