Results 1 to 4 of 4
Thread: Exposed rotor head pictures
    DIY Member vaman's Avatar
    Jul 2009
    NJ
    Default Exposed rotor head pictures
    Here are two pictures that better explain my situation with the exposed rotor head. One shows the exposed head and the other shows the supply line. You experts toss around all kinds of terms about the supply line which I don't understand so I thought the picture would best explain the situation.I replaced the entire rotor head unit with the same model as the original and did nothing to the supply line. It is lying horizontal in the ground. Only thing I can think to do is cut the supply line and add some extra so I can bury it deeper.Ideas are appreciated.
    DIY Member
    Jun 2009
    northeast
    First thing to do is is to cap the fitting so dirt does not enter. The fitting appears to be connected to swing pipe which is very flexable. Dig back and expose the swing pipe for about 12" or so. this will give you room to lower the head a couple of inches. If the swing pipe is short where you do not have much flexability, you may have to dig back to the line that feeds it and lower it a bit. Put teflon tape on the fitting before replacing the head.
    Black pipe is unusual so what you can do depends on whether the pipe is rigid or flexible, and how you could connect any revisions to it, since black pipes can seldom be glued.
    Jul 2009
    NJ
    Did as you suggested and it worked! Thanks
  1. Rotor Heads Exposed
    By vaman in forum Irrigation / Sprinkler Forum
    Last Post: 06-01-2010, 06:09 PM
  2. Rotor heads are too low
    By blown in forum Irrigation / Sprinkler Forum
    Last Post: 05-26-2010, 06:47 PM
  3. Exposed Pex in house?
    By dripdrip in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-16-2009, 12:50 AM
  4. Exposed Wiring
    By Wrex in forum Electrical Forum discussion & Blog
    Last Post: 07-28-2008, 05:28 PM
  5. Glycol and wet rotor circulator breakdown
    By luc in forum HVAC Heating & Cooling
    Last Post: 11-22-2007, 08:51 AM
