Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: code for vertical drop for toilet/tub, IPC
  1. #16
    DIY Member atuel's Avatar
    Nov 2008
    North Carolina, IPC Code
    This look better? Sort of screwed up the top view as the ptrap should angle back toward the bottom of the image as its in the same line with the toilet.
  2. #17
    That works for me.
    Good job.
    You don't need cleanouts above, the CO on the 4" is all you need.
  3. #18
    Jun 2009
    Penticton, BC
    That will work! You obv learned a thing or two!
  4. #19
    Nov 2008
    So got the duct work out of the way and found a little kink in things. The vent I thought was going out the top of the sink is not. Theres actually a 4th pipe I didnt see before that goes up to catch a double vanity on the second floor bathroom before venting out the roof. This 4th pipe hooks into the 3" main line a couple feed back from where the toilet does. Thats the closest thing to venting the toilet/sink/tub in the downstairs bathroom has.
    So I do still need to move everything up and out of the middle of the space, so I'm proposing the following. This gets the vent in the top rather than the bottom of everything, but is a bit on the funky side so wanted to run it by you guys.
  5. #20
    Nov 2008
    I should mention, none of this is going through the joists... its all directly under the joists at the right side and tapering lower as you move left.
  6. #21
    Nov 2008
    never mind... that was a terrible idea. Would have cut too much out of my height that is the whole reason I'm doing this in the first place.
    I dont really know if the sink is vented or not cause I cant tell behind the vanity, but it elbows over to the side, so signs point to its probably not vented unless they have a san-tee in there that connects back in with another vent in the wall somewhere.
    But this should be better for my height needs and allow it to be vented one way or the other.
  7. #22
    Well, now the shower isn't vented.
    Why did you change it?
  8. #23
    Nov 2008
    I have a 4th pipe that connects in that was hidden beind the air duct. Now that the duct isnt obscuring it, I need to find a way to connect it in as well. I've also got a better view of everything to see the concrete pillar in there.
    I see your point though... will angling the wye the shower connects to over to 90 degrees instead of 45 and dropping the ptrap so it wouldnt take a down turn satisfy venting?
  9. #24
    Nov 2008
    So maybe some real pics would help. Now that the duct is out of the way, you can see everything in one shot.
    This one shows the area I need clear. Its about 5' wide and I need 4' and pretty much all of the height except maybe a few inches.
    This is from the opposite side showing which fixture is which.
  1. Vertical Drain Drop Limit?
    By bengal21 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2009, 07:17 AM
  2. Can I install toilet vent in vertical section of pipe below toilet?
    By dayster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2008, 10:36 AM
  3. Vertical drain drop from toilet
    By hanktr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-15-2008, 07:12 PM
  4. Toilet and Vertical Sanitary Tee
    By seaneys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2007, 07:18 PM
  5. 12" vertical drop on tempering valve?
    By dubious in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2005, 04:09 PM
