Results 1 to 2 of 2
Thread: replacing element in copper boiler
    DIY Junior Member davie60's Avatar
    May 2010
    scotland
    Default replacing element in copper boiler
    hi i am trying to replace the element in an copper boiler i have drained the water from the tank in the loft through the hot taps but the tank still seems to be full is it safe to remove the old element any help much appreciated
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    You need to find some way to let air into the unit to finish draining the tank !
    If you have some type of pop off safety valve what we call here a temp/pressure relief
    valve, that you can pop open or remove to allow the tank to finish draining or open the
    cold water taps in the house with the main cold water valve shutoff ?
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  1. Replacing heat element
    By commosmart1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2010, 05:43 AM
  2. Replacing old boiler
    By franjr in forum Boiler Forum
    Last Post: 12-07-2009, 06:22 AM
  3. Thermostats : Dual Element in a Single Element Water Heater
    By Synicasm in forum Water Heater Forum, Tanks
    Last Post: 11-09-2009, 01:35 PM
  4. Single element thermostat on dual element heater
    By garycase in forum Water Heater Forum, Tanks
    Last Post: 07-31-2009, 04:51 PM
  5. Back boiler & oil boiler to twin copper cylinder
    By sheen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2006, 04:34 AM
