plumber1,
I've never installed a lead and oakum flange where I'm at.
I don't think anyone has done that around here since the fifties.
(Greater Seattle area)
On a 4" buried in concrete, since the purpose of the flange is mainly to hold bolts, we use a "flange repair ring" that can be installed onto the floor.
Here's a post I found from the old board:
"REMOVE OLD FLANGE- SPLIT THE SIDE OF EXISTING FLANGE WITH COLD CHIESEL N HAMMER.WEAR SAFETY GLASSES.REMOVE THE OLD LEAD , YOUR GOING TO WORK IT A BIT.ONCE FLANGE IS REMOVED , DETERMINE LENGTH FOR NEW FLANGE.DROP NEW FLANGE OVER PIPE THIS IS AFTER NEW SUBFLOOR INSTALLED.PACK JOINT WITH OAKUM LEAVING 1 IN. FROM TOP OF OAKUM TO TOP OF FLANGE.HEAT OLD LEAD IN LADDLE AND POUR IN JOINT. LET STAND FOR A MINUTE AND CAULK (peen) lead with hammer and chiesel. be careful" Outofplumb
