Results 1 to 9 of 9
Thread: trap arm question, UPC
Hybrid View
    Writing, constructionDIY Member Yersmay's Avatar
    Sep 2005
    Los Angeles
    Default trap arm question, UPC
    In a recent thread concerning a washer stand pipe, the length of the trap arm was briefly discussed. One plumber stated that if the trap arm was too short (less than twice the diameter of the trap arm) then an 'S' trap would result. Another expert said that a trap arm could be as short as you need it to be as long as the trap is vented. I'm hoping this can be discussed a bit more. As a plumbing enthusiast, I've always been mindful to keep the length of the trap arm twice its diameter because I thought the weir needed some amount of air to prevent siphoning. However, it stands to reason that if a trap is vented, the length (or lack of it) of the trap arm becomes irrelevant. Or does it? Could the experts re-visit this to further illuminate the requirements? I'd like to understand this better. Thanks in advance.
    IF the arm slopes enough so the connection to the vertical pipe is below the weir of the trap, it WILL create a partial "S" trap, but whether it automatically causes siphonage depends on whether the flow is adequate to fill the pipe. The minimum length requirement has NOTHING to do with it becoming an "S" trap, and I have NEVER had an inspector fail an installation because the trap was "fitting to fitting" with the tee. The length of the tee's branch, plus the distance from the end of the bell to the downward facing elbow, is almost the 4" distance anyway, regardless of how long the pipe piece is.
    Jun 2009
    Penticton, BC
    The minimum length on a trap arm isn't to reduce s-traps from being installed it's to give the trap some space from the venting so that the air moving through the vent doesn't cause the trap to evaporate too quickly.
    DIY Senior Member Hairyhosebib's Avatar
    Jun 2010
    Arizona
    Are running traps not legal in Arizona?
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    A trap arm that is less than 2x the diameter of the arm is considered a crown vented trap, which is illegal.
    Why would anyone INTENTIONALLY install a running trap?
    Dec 2005
    Hawaii
    deleted, duplicate thread
  1. S trap question
    By Interlodge in forum Plumbing Forum Discussion & Blog
    Last Post: 07-24-2009, 12:39 PM
  2. Question about 3/4 S-Trap
    By iminaquagmire in forum Plumbing Forum Discussion & Blog
    Last Post: 03-15-2009, 08:44 PM
  3. P-Trap Question
    By BillM in forum Plumbing Forum Discussion & Blog
    Last Post: 01-25-2009, 07:52 AM
  4. p-trap or modified s-trap question
    By flazoom in forum Plumbing Forum Discussion & Blog
    Last Post: 03-02-2007, 07:47 PM
  5. P Trap question
    By justme in forum Plumbing Forum Discussion & Blog
    Last Post: 05-04-2005, 07:44 PM
