Results 1 to 2 of 2
Thread: Rheem Powervent 2 pilot flame question.
    DIY Junior Member lerdmann's Avatar
    May 2010
    Briggsdale, CO
    Default Rheem Powervent 2 pilot flame question.
    I'll start with the initial problem, no hot water. I went to the water heater, Rheem Powervent 2 on LP gas, opened the access panel to the spark ignitor/pilot assembly to see what was happening. I turned off the power to the unit and when I flipped it on I heard the ignitor start popping like normal. It took it a couple of times of shutting off power but it finally fired up.
    Now the question. When it ignited I noticed that there is a small flame burning back down over the nut and partially onto the pilot gas inlet tube. It looks like it's been doing this for some time do to soot buildup around the nut and onto the assembly. I guess my question is, should I be concerned about the flame coming back down over the nut and slightly onto the pilot gas inlet tube? Is it something that could eventually "burn through" the line? Thanks in advance for the help.
    Yes to both questions. Repair the leak, usually by tightening the compression nut.
  1. Pilot Question on Empire Vented Gas Heater
    By molo in forum HVAC Heating & Cooling
    Last Post: 05-08-2010, 02:44 PM
  2. Can I Draw Exterior Combustion Air In For My PowerVent Water Heater?
    By ahadave in forum Water Heater Forum, Tanks
    Last Post: 01-23-2010, 05:25 PM
  3. Perfect Flame GSN3318N
    By rbest23 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-03-2009, 08:42 AM
  4. PowerVent Water Heaters
    By Dunbar Plumbing in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2006, 08:14 AM
  5. Gas Water Heater Pilot Question
    By Quibbley in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-01-2006, 07:27 PM
