Results 1 to 6 of 6
Thread: Supply (& DWV) lines in exterior walls
    DIY Senior Member DavidTu's Avatar
    Dec 2009
    Seattle, WA
    Default Supply (& DWV) lines in exterior walls
    Perhaps Terry is best one to answer this one as I'm in Seattle so he knows the weather.... I'm wondering if it is acceptable to run supply lines in an exterior wall? (We'd be able to insulate.) As none of the bath's interior walls are shared w/ the downstairs (large open kitchen area) my other choice would seem to be to run up to attic and back down. What's best?
    (For sure I'd have to run the drains down the exterior... I assume that is fine?)
    Jan 2006
    Rosedale, Md
    Quote Originally Posted by DavidTu View Post
    The trouble with questions like this is all your answers have to be comfirmed by your local jurisdiction.
    A lot of areas will allow supply lines on exterior walls, but they require insulation on the outer wall and none on the pipe, the pipe has to be run as close a possible to the inner wall.
    Most attics are cold areas, not a good idea to run water pipe in there.
    Drains run on the exterior are usually not permitted, like I said you have to ask locally, sorry.
    Dec 2009
    Seattle, WA
    Quote Originally Posted by shacko View Post
    Does that mean you cannot have a fixture on the exterior wall (i.e. drop down wall to floor level) or that you cannot have a stack on the exterior wall? (or both!?)
    (No insulation on pipe so that inside air can warm it, right?)
    In Seattle you can do it.
    Just don't insulate the pipe in the wall, make sure the blanket of insulation is on the outside.
    If you put pipe insulation around the pipe in an outside wall, it will freeze quicker.
    It needs to get warmth from the inside of the home.
    Running pipes in an attic
    Don't put any insulation around the pipes.
    Remove all insulation below the pipe, and lay fiberglass batts over them.
    Between the ceiling joists on either side, lay two more batts, keeping space open below the pipes.
    The heat from the home must be able to get to the pipes, and then you trap it.
    A pipe in an uninsulated attic will freeze otherwise.
    If you change the pipes, then PEX would be good.
    Example of pipes in an attic.
    Dec 2009
    Seattle, WA
    Double check: You mean you can do both, right? (i.e. DWV and/or supply lines in outside walls)
    In Seattle it never gets that cold.
    Surrounded by water on both sides, the Salish Sea (Puget Sound) to the West and Lake Washington to the East.
    Seattle plumbing code allows waste, vents and water in exterior walls.
    As always, during a cold snap you should open doors on exterior cabinets to allow warm air to the exterior walls that have plumbing ( kitchen sinks are a biggie)
  1. How to insulate the exterior walls under a 3 season room.
    By Rughead in forum Remodel Forum & Blog
    Last Post: 04-14-2010, 07:08 AM
  2. Basement insulation -- XPS on just exterior walls?
    By ironspider in forum Remodel Forum & Blog
    Last Post: 03-02-2010, 12:35 AM
  3. Fuel Oil Lines Exterior Specs NJ
    By rlbarkleyii in forum Boiler Forum
    Last Post: 08-08-2009, 05:36 AM
  4. water lines, exterior walls, winter cold...
    By doc5md in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-06-2009, 05:20 PM
  5. Corner Shower on Exterior Walls
    By wvsamdog in forum Shower & bathtub Forum & Blog
    Last Post: 11-12-2005, 01:21 PM
