Results 1 to 3 of 3
Thread: Buderus GB142 and outdoor reset
    DIY Junior Member jhetri01's Avatar
    May 2010
    PA
    Default Buderus GB142 and outdoor reset
    Hi all,
    I'm thinking of having a GB142 installed. I looked through some online documents and noticed that the GB142 has a built in connection for an outdoor sensor. My salesman says I will need an AM10 module to do the out door reset. Can anyone clarify....if out door reset is built in, why is the AM10 needed? Thanks in advance!
    Not sure, but mine has that controller. The ability to use an outdoor reset is built-in, but the adjustments of how and what it is supposed to do are done on the AM10.
    In the Trades Wally Hays's Avatar
    Nov 2009
    The AM10 is the modulet that interfaces with the boilers aquastat. It reads temperatures and handles the algorythm. Definately worth the expense. Every boiler should have outdoor temperature reset capability. I believe that by 2012 manufacturers are required to have it on all hydronic equipment.
    Perception is 3/4 of reality
  1. Honeywell Aquastat & Outdoor Reset Module
    By LMB in forum Plumbing Forum Discussion & Blog
    Last Post: 01-25-2011, 09:42 PM
  2. Honeywell Outdoor Reset Module
    By Backglass in forum Boiler Forum
    Last Post: 09-30-2009, 05:03 PM
  3. buderus wall-hung won't fire
    By shenelec in forum HVAC Heating & Cooling
    Last Post: 11-25-2007, 11:15 AM
  4. odor from direct vent Buderus boiler
    By marsol in forum HVAC Heating & Cooling
    Last Post: 06-11-2007, 06:46 AM
  5. Outdoor Reset Control
    By schwhere in forum Plumbing Forum Discussion & Blog
    Last Post: 02-09-2007, 08:37 PM
